Wisconsin Engines
Need to identify wisconsin engine
this thread has 5 replies and has been viewed 2354 times
Old 09-10-2014, 11:01:56 AM
stenchmiester stenchmiester is offline
Default Need to identify wisconsin engine
Got this engine off a w3ld er a guy had and all I know is its a Wisconsin. The engine is massive close to almost 3 ft tall bur I don't know how to upload a pic on here
Old 09-10-2014, 12:56:09 PM
stufforbud stufforbud is offline
Default Re: Need to identify wisconsin engine
Is there no tag with model or serial numbers? How many cyls?
Old 09-10-2014, 07:18:47 PM
It is a single cylinder. There was a metal tag that bused to be stamped across front of housing with 4 rivets but is gone.
---------- Post added at 06:18 PM ---------- Previous post was at 06:12 PM ----------
Block sump are is stamp AA-91-A.
Old 09-13-2014, 08:26:40 PM
Zira Zira is offline
A picture is worth a thousand words.
That being said, is the block a single casting or does the cylinder bolt on to the crank case? Is the magneto base mounted or flange mounted? Is the spark plug verticle or at a 45-degree angle? Does the exhaust screw into the block at an angle or is it perpendicular to the crank shaft, or does it screw into the intake manifold? Is it a side draft carb or an up draft carb, what brand, and what L-number is on it? What is the Y-number is on the magneto? How many head bolts?
I suggest you Google "Wisconsin engine" combined with the following model numbers, that will tell you what family it is in: AHH, AEH, ABN, BKN, AENL, S-12. Or go to the Wisconsin Llc web site and browse the parts diagrams.
Old 09-19-2014, 05:49:19 AM
Well according to the Aa-91-A stamped on the sump it spears to be an aenl. Block and sump are one exhaust threads into block on an angle. Spark plug is straight out of head. And spears to be an up draft style carb. With air cleaner mounted up like a stack
Old 09-20-2014, 09:10:25 AM
Yep. That sounds like an AENL (or the less common AEN which is very similar). The whole manual (not just the parts list) is on the Wisconsin LLC web site. Common engine, lots of parts available. Good working engine too.
Wisconsin V4 help identify Model E27N Wisconsin Engines 1 11-07-2012 11:53:07 AM
Please Help me Identify this Wisconsin Bigjoedo Wisconsin Engines 6 05-20-2012 08:58:29 AM
Help to Identify Year of Wisconsin Engine wheelhorse4u Garden Tractors and Mowers 1 08-31-2010 09:48:37 PM
Help to identify Wheel Horse Wisconsin engine wheelhorse4u Garden Tractors and Mowers 3 08-30-2010 09:14:05 PM
Help identify a Wisconsin will s Wisconsin Engines 5 12-13-2009 01:48:26 PM
