Go Back   SmokStak > SmokStak® General Discussion > Smokstak Canada
Smokstak Canada For Canadian Smokstakers to meet, greet and have local discussion.
Smokstak Canada
IHC LA LB 1 1/2-2 1/2 HP Brass Handle Flywheel
this thread has 1 replies and has been viewed 1416 times
Old 11-25-2014, 10:16:54 AM
nebbie99 nebbie99 is offline
Default IHC LA LB 1 1/2-2 1/2 HP Brass Handle Flywheel
Flywheel rear drilled with numerous balancing holes. Also I have read somewhere that this wheel with the brass handle was only used one year (1945) and a brass hopper cover was used that year also to celebrate the end of WWII.
ID:	211767   Click image for larger version
The Following User Says Thank You to nebbie99 For This Post:
Old 11-30-2014, 11:41:07 AM
Farmall Jod Farmall Jod is offline
Default Re: IHC LA LB 1 1/2-2 1/2 HP Brass Handle Flywheel
Yeah I remember reading in a post before that the brass handle was used only one year (of course other year models would have gotten them through repairs/replacement handles etc) but I was under the understanding it was for some sort of anniversary of IH while I have read that IH would make parts from scrap brass from other models and recycle it due to wartime shortages
John Deere Type E Flywheel handle hulou Hit & Miss Gas Engine Discussion 5 09-26-2013 04:56:07 PM
Starting crank handle Id wooden handle Matt1931 Hit & Miss Gas Engine Discussion 3 07-29-2013 06:49:17 AM
Stover KE,spoke flywheel,solid flywheel weight interchange Matthew Guy Clarke Hit & Miss Gas Engine Discussion 2 12-22-2012 04:14:11 PM
1945 IHC LB 1 1/2 brass handle wielenberg123 Hit & Miss Gas Engine Discussion 6 01-12-2011 07:40:22 PM
IHC LB brass cranking handle question David Babcock Hit & Miss Gas Engine Discussion 13 06-22-2010 10:03:31 PM
