Oil Field Engines
20 HP Reid Engine
this thread has 3 replies and has been viewed 1846 times
Old 03-28-2015, 07:34:59 PM
2030rumely 2030rumely is offline
Smile 20 HP Reid Engine
Does anyone know what a 20 hp. Reid Oil Field engine weighs? Is there a list of serial numbers to identify the year they were built? What does the orginal cooling tank look like?
Thank you for any information to the above.
Oiler.http://www.smokstak.com/forum/images/smilies/shrug.gif
Old 03-28-2015, 08:58:44 PM
Tom Geier's Avatar
Tom Geier Tom Geier is offline
Images: 51
Default Re: 20 HP Reid Engine
6500 lbs. have a lot of info on reid engines on "oilfield engine society" on facebook
Do i really look like a people person?
The Following User Says Thank You to Tom Geier For This Post:
Old 03-28-2015, 10:21:59 PM
Thank you Mr. Geier for the information. It is really helpful trying to find out about a new engine.
Old 04-05-2015, 09:35:58 PM
The original cooling tank could have been most anything or nothing at all! If there was an adequate water supply nearby they could have just run flowing water thru the engine, perhaps with the aid of a pump. It could have been a wood or steel tank outside the building plumbed up to thermosyphon or percolate thru the engine or pushed with a pump.
The worst case scenario was utilizing the brine from the well and letting it flow thru before being discharged- this led to a lot of crusting in the water jacket. I have removed a few that were connected up to a radiator and the water was circulated much like in an automobile. Bill Klein
Reid Engine Kevin Stone Oil Field Engines & Related Equipment 16 07-02-2008 11:35:55 PM
The OTHER Reid engine Doug Waggonner Oil Field Engines & Related Equipment 0 02-05-2007 10:58:14 PM
Odd Reid Engine Jon Rozevink Antique Engine Archives 0 07-08-2004 10:35:13 PM
Reid engine Al Steppich Antique Engine Archives 3 09-25-2002 08:07:32 PM
Reid? Engine Hal Davis Antique Engine Archives 13 08-22-2001 10:24:45 PM
