Oil Field Engines
40Hp Superior
this thread has 2 replies and has been viewed 1425 times
Old 07-23-2015, 09:33:23 PM
71ford100 71ford100 is offline
eMail NOT Working
Default 40Hp Superior
Does anyone know the approximate weight of a 40HP Superior?
Thanks!
Old 07-23-2015, 10:22:15 PM
Greg Mosley Greg Mosley is offline
Default Re: 40Hp Superior
If its an Oil Country Engine gross weight less clutch is 9130 lbs. If its a Mill Style it tips the scales @ 9800 lbs less clutch. Enuf Said.
The Following User Says Thank You to Greg Mosley For This Post:
Old 07-25-2015, 12:46:56 AM
DirtbikePilot DirtbikePilot is offline
Better specify which type it is. They made a two stroke in at least 2 styles and the 4 stroke side shaft types.
40hp Reid JWithers Antique Gas Engine Discussion 26 09-17-2014 09:35:46 AM
40hp Superior.. Randy L Peterson Oil Field Engines & Related Equipment 1 05-06-2013 05:09:25 PM
Where are all the 40hp Averys? Gary Biewer Steam Stationary Engines, Traction Engines 61 06-01-2012 09:04:14 PM
Fairbanks Y-VA 40Hp Weight Scott Hosack Vintage Diesel and Oil Stationary Engines 1 02-28-2011 12:07:08 PM
Ken Eder's 40hp Avery??? GaarScott Steam Stationary Engines, Traction Engines 10 01-22-2008 07:47:04 PM
