Oil Field Engines
Rebuilding A 25 HP Superior Governor
this thread has 0 replies and has been viewed 902 times
Old 11-12-2015, 08:08:52 PM
2030rumely 2030rumely is offline
Default Rebuilding A 25 HP Superior Governor
I thought some of you might enjoy hearing about how we rebuilt the governors on our two 25 hp Superior engines. All of the pivot pins were worn and the main drive shaft was worn and the hole in the casting was also egg shaped and oversized. The pivot pins were easy the big challenge was the worn drive shaft and the casting it runs in. At first I was going to put a new bronze bushing in each end of the casting. But with the pivot pin arm on the top of the casting made it impossible to chuck up in the lathe. I decided the easiest way was to pour a babbitt bearing full length of the casting. There is a machined surface on the lower end of the casting so I chucked it in the lathe on this end and then drilled a one inch hole through the casting. I cleaned up one of the shafts on the lathe. The second one was bent so I made a new one for it. I had to drill out the pins holding the drive gear on to the drive shaft. I replaced them with roll pins. I have attached some photos of the progress. Hope this might help someone with the same problem.
Name:	November 11 2015Truing up governor  shaft on the lathe 1.jpg
ID:	238716   Click image for larger version
Name:	November 11 2015  Drilling governor casting for b abbit bearing 1.jpg
ID:	238717   Click image for larger version
Name:	November 12  2015  New babbitt bearings governor shaft 1.jpg
ID:	238718   Click image for larger version
Name:	November 12  2015 Rebuilt governor installed 1.jpg
The Following 8 Users Say Thank You to 2030rumely For This Post:
Rebuilding Bearings Warren Wolf Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 9 04-04-2012 07:17:47 PM
Rebuilding a Wico EK mikesautosvc Magnetos, Ignition Coils and Spark Plugs 4 09-30-2011 07:01:46 PM
rebuilding 15 HP REID governor Bob Johnson Oil Field Engines & Related Equipment 0 10-05-2007 01:57:33 PM
rebuilding 25 A&T Jeff W B Steam Stationary Engines, Traction Engines 3 02-17-2007 09:15:25 PM
Crankshaft Rebuilding Keith Antique Engine Archives 4 02-11-2002 07:41:18 PM
