Oil Field Engines
Fairbanks ZC-52 Trouble
this thread has 3 replies and has been viewed 2456 times
Old 10-20-2006, 11:33:17 AM
Adam L. Adam L. is offline
Default Fairbanks ZC-52 Trouble
I am currently restoring a Fairbanks Morse ZC-52 and I got it running off of the start tank perfectly. When i switch it over to the run tank i have to choke it fully to keep it running and even then it runs poorly. The fuel line assembly is new and i believe it to be set up correctly. The check valve seems to work well when i blow threw it and the line seems to be clean. Does anyone know what might be the problem?
Old 10-21-2006, 08:10:53 AM
Allan Wright Allan Wright is offline
Default Re: Fairbanks ZC-52 Trouble
Adam, it sure sounds like a check valve problem to me. Is the check valve in the tank or outside? Another thing to check would be to take the needle valve out and run a wire through the jet to make sure it is clear. Is there a union on the gas line that could be leaking?
Good luck with it.
Allan
Old 10-21-2006, 08:39:30 PM
Jim Gorter Jim Gorter is offline
Also check to make sure the small hole in the run side needle valve is clear and the gasket that holds the needle valve base is secure and tight, might be sucking air. Good Luck Jim.
Old 10-22-2006, 11:07:57 AM
Elden DuRand's Avatar
Images: 11
Is the "flutter valve" alive and well? The flutter valve is the disc with a spring behind it that fits on the air inlet of the mixer. If the spring is too weak or missing or the disc is rusted or warped and doesn't seat well, that could cause it to not have enough suction to draw fuel from the tank.
The reason it runs okay on the priming chamber is that the fuel does not have to be drawn nearly as far.
Take care - Elden
http://www.oldengine.org/mdmbers/durand
6HP Fairbanks Morse trouble starting Chris Steffen Hit & Miss Gas Engine Discussion 8 09-30-2009 09:15:52 PM
1 1/2 hp Fairbanks Z trouble Skip Landis Hit & Miss Gas Engine Discussion 3 01-04-2008 10:19:11 AM
Fairbanks Morse Trouble SethM Hit & Miss Gas Engine Discussion 15 06-11-2007 09:52:42 PM
Fairbanks ZC-52 Trouble Adam L. Hit & Miss Gas Engine Discussion 3 10-21-2006 10:52:49 AM
Fairbanks Mag Trouble Tracy Schroeder Antique Engine Archives 1 05-17-2003 10:31:08 PM
