Oil Field Engines
Fairbanks Morse ZC-52 more help!
this thread has 1 replies and has been viewed 2258 times
Old 10-24-2006, 10:24:17 AM
Adam L. Adam L. is offline
Default Fairbanks Morse ZC-52 more help!
Your replies were very helpful and thank you. The engine is running much better now but is still misses and pops more than it should. It still runs perfect on the prime tank. When its on the run tank it will run good for a minute and then spit and sputter for a minute, then run good for a minute more. I let it run for about 30 minutes but no change.
I made sure that it was not leaking air around any of the joints and i removed the flutter valve (new) and did some work on it.
It has brand new valves, seats, and springs in the head but it blows a little gas back threw the intake. When i hold more tension on the intake valve spring this stops and the engine runs quite a bit better. Does anyone know what this means? Thanks in advance for all the help!
Adam
Old 10-24-2006, 02:37:18 PM
Jim Gorter Jim Gorter is offline
Default Re: Fairbanks Morse ZC-52 more help!
Sounds like you have found at least a partial answer to your problem. The new spring may still be too light to hold the intake closed. Try a stiffer spring or some guys put spacers under the spring to increase the tension a bit. While you have the spring off, move the valve in and out to check for smooth operation and turn the valve in the seat to make sure there is no carbon on the faces holding the valve open, Good Luck, Jim.
Fairbanks Morse Z thiggy Hit & Miss Gas Engine Discussion 4 03-10-2015 04:09:22 PM
Fairbanks Morse ZD J Mag Help.... Redhookred1 Magnetos, Ignition Coils and Spark Plugs 3 07-10-2014 03:55:27 PM
Fairbanks Morse ZD 2HP Gilbert Armour Hit & Miss Gas Engine Discussion 3 07-05-2014 03:14:59 PM
37 1/2 hp fairbanks Morse 48bomber Hit & Miss Gas Engine Discussion 3 06-25-2014 12:21:59 AM
FB/Morse-Need a Part- Morse Fairbanks Ser# 833745-1942? Babbit? LShap1777 Hit & Miss Gas Engine Discussion 4 09-12-2008 11:03:58 AM
