Wisconsin Engines
Help identify a Wisconsin
this thread has 5 replies and has been viewed 1669 times
Old 12-12-2009, 11:18:49 AM
will s will s is offline
Default Help identify a Wisconsin
does anyone know model no.,if crank has splined or keyed for pulley,what it went on? thanks
ID:	69027   Click image for larger version
Old 12-12-2009, 11:43:32 AM
John Newman, Jr.'s Avatar
Default Re: identify wisconsin
Looks like a Wisconsin Model AHH. This is the biggest single cylinder engine they made. The crankshaft end is probably keyed, but since it has a clutch & gear reduction unit, the end of the crank is likely to be shorter than usual. If you remove the gear / clutch unit you will probably only have a stubby shaft to work with.
John Newman, Jr.
Saint Louis, MO
I Can Probably Fix That
Old 12-13-2009, 12:07:59 PM
Zira Zira is offline
I's not an AHH, it has a different exhaust & carb set up. I believe it is an AGND. Does the cylinder jug bolt on to the crank case? As John said, it will probably have a "stubby" crank shaft with a keyway. I don't have a standard AGND crank case or crankshaft, if it was an AHH I could help you out.
The Following User Says Thank You to Zira For This Post:
Old 12-13-2009, 01:02:25 PM
thanks do you have any idea wghat it was used on?
Old 12-13-2009, 01:11:47 PM
Will,
One possibility is the engine may have been used on a grain auger.
Bill
The Following User Says Thank You to Bill Sherlock For This Post:
Old 12-13-2009, 01:48:26 PM
Sorry about my mis-identification. I was going by the location of the mag and didn't give too much thought to the carb & exhaust....
John Newman, Jr.
Saint Louis, MO
Can anyone identify? Allan Clark Steam Stationary Engines, Traction Engines 24 09-17-2007 10:42:25 PM
Please help identify Tom Lewis Generators & Electric Motors General Discussion 5 11-05-2003 07:28:14 PM
Can anybody Identify this Paul Hokanson Antique Engine Archives 8 03-14-2003 09:13:15 AM
please identify genset wisconsin?? steve tyson Generators & Electric Motors General Discussion 2 12-27-2002 03:18:32 AM
Help Identify Mike Shaffer Antique Engine Archives 3 12-24-2002 12:39:58 AM
