Smokstak Down Under
Machining a Connecting Rod Casting
this thread has 1 replies and has been viewed 2025 times
Old 04-08-2010, 10:49:18 AM
P Grogan P Grogan is offline
Default Machining a Connecting Rod Casting
hi can anyone help with the machining of a conrod ?
i have the casting thanks for any help. :cool:
Old 04-08-2010, 01:46:02 PM
peterR peterR is offline
Default Re: Machining a Connecting Rod Casting
I made a con rod for my Amanco, see http://gasengine.farmcollector.com/G...d-Pistons.aspx. which should provide some answers. In short, you will need to clean up one face of the casting so you can bolt it square to the milling table then bore the big and little ends. Drill the holes for the big end bolts, then slit the big end.
Get in touch with me if you have any questions
Peter
The Following User Says Thank You to peterR For This Post:
The Machining of an Ignitor IronCity2006 Hit & Miss Gas Engine Discussion 44 06-02-2009 03:26:38 PM
Casting and machining a flywheel Chris Kirk Antique Engine Archives 7 08-23-2004 10:19:27 PM
Casting repair/ new casting Doug Edwards Antique Engine Archives 1 01-14-2003 01:26:04 PM
Machining Question Frank Gassett Antique Engine Archives 4 06-12-2002 02:44:04 AM
