IHC LB brass cranking handle question
this thread has 13 replies and has been viewed 3371 times
Old 06-03-2010, 02:26:07 PM
David Babcock David Babcock is offline
Question IHC LB brass cranking handle question
Ive seen quite a few international type lb engines thru the years. A few seem to have brass cranking handles! I have been checking on the serial numbers of these engines and they all seem to be 1945 engines. Iam guessing this is a symbol for the end of ww2?? Does anybody have any insight on this? Thanks db.
Old 06-03-2010, 04:55:21 PM
vern0n's Avatar
vern0n vern0n is offline
Default Re: Ihc lb brass cranking handle question
If I remember right, from a past tread, there is no ryme or reason why some have a brass handle.
Old 06-03-2010, 08:17:43 PM
Will Batty's Avatar
Will Batty Will Batty is offline
Images: 33
Default Re: IHC LB brass cranking handle question
I thought I read somewhere it was to with 1945 being some sort of an anniversary year for IHC, but I don't know what they were celebrating?
Old 06-03-2010, 08:51:44 PM
Brian Lynch's Avatar
Images: 23
I have two 1-1/2 to 2-1/2 hp LA's that have brass crank handles. Both date to 1937. Maybe brass was cheaper than cast iron at times?
Old 06-05-2010, 06:02:53 PM
I have always thought that the handle was brass due to the "brittleness' of cast iron and the danger of the handle breaking off and going ballistic. Good luck in a good hobby Joe Morris
Old 06-05-2010, 07:42:37 PM
John Ledbetter's Avatar
John Ledbetter John Ledbetter is offline
Images: 25
I have a McCormick/IHC LA Engine 1 1/2 hp # 12511 that has a brass hopper cover and has IHC logo cast inside
Also have a 3 to 5 hp LB # 43641 with a brass crank handle
Name:	IHC McCor.1.jpg
http://2enginejohn.blogspot.com
Old 06-07-2010, 12:19:06 AM
Jean-Guy Lirette's Avatar
Jean-Guy Lirette Jean-Guy Lirette is offline
Images: 8
Hi David
I collect LA and LB engine since a couple of years ago and I love finding all sorts of different things and information for these engines.
About brass crank handle that you mention, I already own three different models of cast iron. I have not found yet handle brass.
What makes you say that the handle is brass? Is the color of the metal or the magnet does not stick to metal?
Is it possible for you to send me a photo of this brass crank I want to see his form?
Thank you for the information.
Old 06-07-2010, 07:05:34 AM
Doug Kimball's Avatar
Images: 78
Jean-Guy,
Here's one I used to own .... 1 1/2 - 2 1/2 hp LB. Definitely brass, someone painted it red but paint was flaking off.
Name:	DCP_0217 (Small).JPG
In Kennebunk, Maine;
Doug Kimball
Old 06-09-2010, 07:50:43 PM
smgussey smgussey is offline
I have a brass handle 3-5 and also a 1.5-2.5 with a brass handle. Not sure on the year/serial number... I was told some anniversary by someone a long time ago, too.
Old 06-09-2010, 10:33:05 PM
SDP's Avatar
SDP SDP is offline
I found this brass handle at a local show last year for $15, with flywheel included!
The only marking on the handle is the IHC logo, no numbers.
It is most definitely brass since it dents so easily....
ID:	80727   Click image for larger version
"Liberalism is the transformation of mankind into cattle."
Friedrich Wilhelm Nietzsche (1878)
The Following User Says Thank You to SDP For This Post:
Old 06-12-2010, 11:09:05 AM
Harv Harv is offline
Hi Reading the remarks re the brass handels on IHC LAs or LBs I have beden collecting these engines for a few years by now and was told in no uncertain terms by an older gentelman at a show that i had some of my brass handels on the wrong engines as they belonged to the 1945 production which was a celebration of the 10th full year of production of this IHC line and it also was a celebration pof the end of the war I brelieved this gentelman as he had worked at the IHC factory during this time Even in spite of this info i have left my brass handels on any of my show engines because i trhink they look real good HARV
Old 06-12-2010, 12:26:16 PM
vern0n's Avatar
Maybe the brass handle were replacement handles if your old one broke.
Old 06-12-2010, 02:05:45 PM
vern0n's Avatar
Just went and checked my brass handle engine, sure enough it is a 1945.
Old 06-22-2010, 10:03:31 PM
Nathan K. Nathan K. is offline
I finally found my engine list to check and sure enough my brass handled 3-5 LBB is a 1945. Nathan.
cranking time dr fusion Onan Generators 9 11-14-2009 05:27:04 PM
Need help cranking my engine daydk1 Antique Gas Engine Discussion 14 01-03-2009 09:14:11 PM
Briggs Brass Carb Question Jeff Schoch Small Air Cooled Gasoline Engines 7 11-08-2008 10:44:54 PM
Backfire while cranking caseyvand Antique Gas Engine Discussion 6 09-09-2008 11:07:45 AM
4.0 Bfa Cranking Problems pnora Onan Generators 6 04-17-2006 09:13:46 PM
