How to Handle a heavy piston!
this thread has 10 replies and has been viewed 2188 times
Old 10-19-2010, 05:38:48 PM
David M. Lyon's Avatar
Default How to Handle a heavy piston!
Here is how to handle heavy pieces like this 15 Horse Fairbanks-Morse piston!...Done got to old to manhandle some of this stuff. But, I'm a sucker for a BIG engine!~
Just can't stay away from 'em.
(Best runnin' ol' 8N Ford tractor in the South!~)
Name:	15 horse fm piston 001.jpg
The Following 4 Users Say Thank You to David M. Lyon For This Post:
Old 10-19-2010, 05:57:01 PM
Chuck Foster's Avatar
Chuck Foster Chuck Foster is offline
Default Re: How to Handle a heavy piston!
i just thought i would be the first one to comment on the lack of care for the rod bearing...............steel chain on a babitt rod bearing
i just had to make this comment
chuck
Old 10-19-2010, 06:02:39 PM
oh ya .......... lets see the rest of the engine............please
chuck
Old 10-19-2010, 06:25:33 PM
Somebody had done a poor babitt pour sometime in it's past...I'm gonna' replace the bearing anyway!...But yes!...If it were a good bearing, I would've at least padded it with a rag or sumpthin'
Old 10-19-2010, 08:42:25 PM
Dick Bauer's Avatar
Dick Bauer Dick Bauer is offline
Got one just like it, done been there already but without the tractor help.
Old 10-19-2010, 08:48:44 PM
Jim Martin's Avatar
Jim Martin Jim Martin is offline
Looks like that works OK David,,I've pulled a 12hp Waterloo and 12Hp Economy pistons out & back in the last couple of years,,and they're hard to do by yourself,,and that looks even heavier,,,whatever it takes!,,,,,,,Jim
Old 10-19-2010, 09:03:23 PM
chuck
Here is what it came out of, Chuck....I am having to replace the cylinder because it was cracked so badly across the bottom, the lower head stud wouldn't stay tight and kept blowing head gaskets...Everytime it would blow, it would send a shower of hot water about 50 feet in the air!...Not cool!...People do not like a hot shower at a show...
Name:	disk 5 065.jpg
The Following 2 Users Say Thank You to David M. Lyon For This Post:
Old 10-19-2010, 09:11:05 PM
The Feltermans from Paterson, LA rescued the 100hp Buckeye single cylinder engine, I helped a little on the reworking, 16" piston weighed 400lbs. The front end loader was a welcomed helper.
Old 10-21-2010, 11:47:44 PM
The worst part about a BIG piston?...Gettin' that sucker back in the hole by yourself!~....I almost strained a gut string before i got it to slip back in!~
The Following User Says Thank You to David M. Lyon For This Post:
Old 10-22-2010, 12:12:27 AM
Shock Shock is offline
That is a fine photo. Two works of art.
Old 10-22-2010, 07:12:04 PM
Brian Triebner's Avatar
Brian Triebner Brian Triebner is offline
Bigger pistons sometimes come with threaded holes in the head so you can handle them like this
Sad Iron @ Brians computer...
What does this handle fit? Zira Hit & Miss Gas Engine Discussion 9 01-19-2009 06:35:57 PM
Piston Ring Material for Custom Machined Piston Rings. Uncle Old Iron Hit & Miss Gas Engine Discussion 3 06-24-2007 01:50:53 AM
How Heavy Is It? Vn 22l PFT Machine Shop and Tool Talk 1 02-18-2007 12:41:09 AM
Heavy Piston-ok or ?? Ed Deis Antique Engine Archives 7 09-27-2004 08:47:21 PM
IH LB handle Kevin Hesse Antique Engine Archives 1 06-01-2004 06:58:12 PM
