Old planer machining a new casting for an old tractor
this thread has 6 replies and has been viewed 4127 times
Old 12-20-2010, 01:15:38 AM
Benjamin Roth's Avatar
Benjamin Roth Benjamin Roth is offline
Default Old planer machining a new casting for an old tractor
Here is something you don't see everyday, a metal planer doing the job for which it was intended.
There was nearly 1/4" of material removed in order for the casting to be the proper thickness. The cuts taken were .050 deep with a .050 step-over and took about an hour and a half to finish a pass.
ID:	95700   Click image for larger version
ID:	95701   Click image for larger version
ID:	95702   Click image for larger version
Old 12-20-2010, 12:19:14 PM
ronm ronm is offline
Default Re: Old planer machining a new casting for an old tractor
I love planers, the high school machine shop had one, a big ol' hydraulic-driven job w/about a 10 foot bed...that thing was awesome...
Old 12-20-2010, 06:51:13 PM
I have always liked running planers. The biggest one I ran had a 24' long table. The one I ran the most had a 14' table. Mostly did paper mill repair work on them. I have always wanted a small hydraulic one at home.
Richard W.
Old 12-30-2010, 11:03:08 AM
Alan Svanes Alan Svanes is offline
What tractor are you working on.
Old 12-31-2010, 11:33:33 AM
Kelly Tytlandsvik Kelly Tytlandsvik is offline
Nice to see the planer working!
Kelly T
Old 01-01-2011, 03:49:20 PM
I finally got the video sorted out (Thanks Craig!).
It might not operate as smoothly as a hydraulic planer but it got the job done. It's also more soothing than running the mill.
The tractor is a 30-60 Mogul that is finally being assembled. The next job will be machining the cam followers; a slightly more intimidating task.
The Following 5 Users Say Thank You to Benjamin Roth For This Post:
Old 05-29-2011, 11:55:31 PM
That Planer looks like a Gray. My Dad had 1 about the same size in the shop behind our house back in the 70's. I remember listening to the belts flap and squeak (at the end of the stroke while shifting) when I was maybe 6or7 years old.Brings back a nice memory. Sadly the old planer went to the scrap yard in the early 80's and was replace by a Cincinatti Hypro 36" by 12' hydraulic . The hypro ran smoother but lacked the neatness of the old belt shifter.I have always kicked myself in the A-- for not saving it.We still have some small antique planers yet like 3 Wilkinsons and a New Haven.They are benchtop models.Someday we'll get 1 set up to play with. Rob
Machining a Connecting Rod Casting P Grogan Smokstak Down Under 1 04-08-2010 01:46:02 PM
Aumann's Album Casting A Pinion Gear for 50 HP Steam Tractor DanBoom Steam Stationary Engines, Traction Engines 0 07-08-2009 11:26:51 AM
Casting and machining a flywheel Chris Kirk Antique Engine Archives 7 08-23-2004 10:19:27 PM
Planer Doug Smith Antique Engine Archives 5 01-12-2004 11:40:11 AM
