1945 IHC LB 1 1/2 brass handle
this thread has 6 replies and has been viewed 1466 times
Old 01-10-2011, 10:02:53 PM
wielenberg123 wielenberg123 is offline
Default 1945 IHC LB 1 1/2 brass handle
I am wondering if in 1945 IHC made a LB 1 1/2 enigne with a brass handle celebrating the 10 yr anniversay of the LA and LB engines? If so did they make them that entire year or just a limited number. Thanks
Old 01-10-2011, 11:29:44 PM
Dan Baalman Dan Baalman is offline
Default Re: 1945 IHC LB 1 1/2 brass handle
Have had a few couple with the brass crank handles. I think this was addressed in a post some time ago. Don't think it was to commemorate anything. Just the foundry must have had some brass in the pot.
Old 01-10-2011, 11:47:58 PM
Chris J's Avatar
Chris J Chris J is offline
Images: 833
A great resource is the search tab here on the site, and also the Similar Threads Chosen at Random shown on the bottom of this page, you may find something helpful to what you are asking.
By The Way Here is the link to the last brass crank handle thread:
http://www.smokstak.com/forum/showthread.php?t=76234
The Following User Says Thank You to Chris J For This Post:
Old 01-11-2011, 09:33:49 PM
I looked through the Archieves on here and found a little more info out about the brass handle LB's. I was still hoping that someone would have read in an IH book sometime along the line the actual reason behind the brass crank handle. I have heard people say the end of the war, the 10 year anniversay of the LB and LA engines. Also what do you guys think is a 1945 LB with a Brass Handle worth more then a 1944 LB both in the same shape? I guess it all amounts to how much i am willing to pay for the engine with the brass handle. What do you guys think is more rare a 1945 LB with a brass handle or a LA or LB engine with the oil bath air cleaner?? Thanks
Old 01-11-2011, 11:47:45 PM
I looked up the two I had with brass handles. One was a 1938 and the other a 1948. I know parts get switched around but I am pretty sure these were original to these engines
Old 01-11-2011, 11:48:38 PM
oldironlindy oldironlindy is offline
I know a guy that would sell you one. Ha Ha
Old 01-12-2011, 07:40:22 PM
lol, Im still waiting for those pictures Lindy! If you had time to take some.
1945 D7 Cat at auction EdDarowski Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 5 08-18-2010 04:44:53 PM
IHC LB brass cranking handle question David Babcock Hit & Miss Gas Engine Discussion 13 06-22-2010 10:03:31 PM
HELP-1945 JD Model A won't start. EugeneKS Antique Farm Tractors 19 02-21-2010 09:28:53 PM
Restoration on a 1945 MM Z std. Tony Thompson Antique Farm Tractors 23 02-19-2008 03:54:45 PM
