Onan genset model #5.0 CCK stops running ater 10 or 20 min
this thread has 15 replies and has been viewed 3106 times
Old 04-22-2011, 06:44:49 PM
M.Linskens M.Linskens is offline
Question Onan genset model #5.0 CCK stops running ater 10 or 20 min
first time to post , look at alot of other post but havn't fond this one. it seems the more power i need from it ,it starts to spudder and die thanks.
Old 04-22-2011, 07:02:07 PM
kg5388 kg5388 is offline
Default Re: onan gen set model #5.0cck stops running ater 10 or 20 min
when it stops will it start right back up and run for 10 to 20 min?
Do you have to wait a certain amount of time before it will start and run again?
When you restart it does the run time stay constant 10 to 20 min or does it get shorter and shorter each time you restart it?
does it run ok without any load or does this problem just occurs when you add load to the genset ?
have you unpluged one plug wire and run the genset then plug it in and unplug the other and try to run it to see if you have a dead cylinder?
The Following User Says Thank You to kg5388 For This Post:
Old 04-22-2011, 07:17:20 PM
BTPost's Avatar
BTPost BTPost is offline
Images: 1
Talking Re: onan gen set model #5.0cck stops running ater 10 or 20 min
This is NOT Possible to do on a Standard Onan CCK Factory wired Ignition System. Simply because, the Spark Plugs are wired in series. So if you unplug a Spark Plug, and do NOT Ground that Spark Plug Wire, the remaining Spark Plug can't fire, because it no longer has a Path to Ground, thru the Coil, as the Coil Secondary is NOT Grounded, internally like a Car Coil. Onan CCK coils are more like Harley Davidson Twin Tower Coils, which are sometimes used to replace Onan coils on the CCK Gensets.
http://www.smokstak.com/forum/showthread.php?t=56022
Bruce in alaska
The Following 3 Users Say Thank You to BTPost For This Post:
Old 04-22-2011, 07:28:35 PM
seems that if i don't put a load it runs longer . i took the low oil wire of the coil but still happens thanks for any info
Old 04-22-2011, 07:44:39 PM
DOH!! my mistake it's been long day and tried to ask the basic questions quickly without thinking CCK
Old 04-22-2011, 07:49:51 PM
hey thats ok, time for a beer !
Old 04-22-2011, 08:14:58 PM
question I forgot and it is one of the important ones
Does it surge up and down like it's running out of gas or does it shut down like you hit the stop switch?
Old 04-22-2011, 08:20:54 PM
well it spudders an pops then stops . i have it hook up to a 5 gal tank an its out of the rv thanks
Old 04-22-2011, 08:32:38 PM
John Newman, Jr.'s Avatar
Could be a simple as a bad condenser...
I would do the cheap / easy stuff first: Points, plugs, condenser. See if that makes any diference and then consider the more expensive items.
John Newman, Jr.
Saint Louis, MO
I Can Probably Fix That
Old 04-22-2011, 08:38:20 PM
thanks i'll try that an let you know if its the fix .
Old 04-22-2011, 09:34:33 PM
MBB MBB is offline
Default Re: Onan genset model #5.0 CCK stops running ater 10 or 20 min
If this problems after the engine is warm but not when first started. A couple of things come to mind. Choke or valve adjustment. If its hard to start after its warm check valve clearance.
The Following User Says Thank You to MBB For This Post:
Old 04-22-2011, 10:01:19 PM
I am real good at asking the stupid questions. What type of tank are you using & is it vented?
The Following User Says Thank You to Max Thompson For This Post:
Old 04-23-2011, 12:30:41 PM
it starts up after it shuts off , i'll take a look at the choke thanks
5 gal. gas tank vented , the only stupid question is one thats never ask thanks
Old 04-25-2011, 11:43:32 AM
Dave Edmonds's Avatar
Dave Edmonds Dave Edmonds is offline
Smile Re: Onan genset model #5.0 CCK stops running ater 10 or 20 min
Improperly set points gap will cause similar problems. Points gap is "acceptable" when unit is cold, but closes (or opens)when unit heats up until the points don't function. A tune-up (new points and condenser) never hurts anything.
Dave Edmonds
The Following User Says Thank You to Dave Edmonds For This Post:
Old 04-26-2011, 03:04:08 PM
thanks thats what i'm going to try , do you know the gap thanks again
Old 04-26-2011, 07:52:35 PM
Ben Cowan Ben Cowan is offline
I believe most cck units use a point gap of 0.020 inches, 20 thousands of an inch. Luck, Ben
The Following 2 Users Say Thank You to Ben Cowan For This Post:
Engine stops running when switched to run. the1moe Generac Generators (SEARS, etc.) 7 03-31-2011 06:43:22 PM
'97 Onan Marquis 7000 Stops Producing Voltage and Still Running MariettaEddie Onan Generators 13 08-26-2010 10:11:52 AM
Maytag 92 STOPS running Todd Hodges Maytag Engines and Collectibles 8 07-13-2009 04:19:06 PM
Onan 4.5 genset starts but stops after start pb is released deproch Onan Generators 1 05-28-2008 05:51:34 PM
Onan BGE consistently stops running after a few minutes scubar Onan Generators 19 02-07-2008 03:54:32 PM
