Onan 50k Military Genset control board rescue
this thread has 12 replies and has been viewed 703 times
Old 02-22-2017, 04:43:53 PM
paridgerunner paridgerunner is offline
Default Onan 50k Military Genset control board rescue
Never fails every time I go to the scrap yard I come home with something new.
Was talking to the man there and looked at one of the scrap bins and sitting on top was a Onan control panel from a 50k generator. No one had a chance to hack it up yet so I asked if we could deal, I couldn't just leave it there.
Everything looks intact even has a schematic embossed on top.
Here are some pics. And yes I asked if the Genset was there Onan 305D316
ID:	275616   Click image for larger version
ID:	275617   Click image for larger version
The Following User Says Thank You to paridgerunner For This Post:
Old 02-22-2017, 07:20:51 PM
Billy J Shafer's Avatar
Billy J Shafer Billy J Shafer is online now
Default Re: Onan 50k control brd rescue
That is an old military unit. Probably not built by Onan. Most of the time Onan just supplied the gen section. Very hard to find parts for. The guys on the military section might have some interest in it. Nice find anyway
Old 02-22-2017, 08:06:25 PM
Thanks Billy for the reply I just could not see letting that thing get scrapped even if it just sits on my shelf
Old 02-22-2017, 09:30:42 PM
Doug Reed Doug Reed is offline
If the unit is military related, the www.steelsoldiers.com web site is a good place to go. They are mainly about vehicles, but they do have a section for generators. They are a good bunch to talk to and helpful.
The Following User Says Thank You to Doug Reed For This Post:
Old 02-22-2017, 09:43:16 PM
Thanks Doug I am a member there also
Old 02-23-2017, 08:48:45 AM
Gunny Gunny is offline
That is off of a Military genset, probably a MEP series. That voltage/phase selector switch I see in there is a good find.
The Following User Says Thank You to Gunny For This Post:
Old 02-23-2017, 09:16:23 AM
Thanks Gunny just posted on Smokstak Military forum someone may enjoy seeing this sure wish genset was also there. I have an old Mep military genset Onan powed 10k all intact and seem to be in good condition including control board can't wait for weather to break to test it out.
Old 02-23-2017, 12:12:12 PM
TooManyHobbies TooManyHobbies is offline
Default Re: Onan 50k Military Genset control board rescue
That looks just like the one on my MEP-017A 5k unit.
The Following User Says Thank You to TooManyHobbies For This Post:
Old 02-23-2017, 01:04:33 PM
May be the same I did see label saying 50k
Old 02-23-2017, 11:13:35 PM
EricWood's Avatar
EricWood EricWood is offline
This is from MEP-017, 5.0KW is what the schematic data tag says... the "dot" is obscured by abrasion/corrosion. Hard to read the bottom rectangular block of text, but the line below "tubular frame" reads beginning with "60Hz, 120/208...etc (voltage select options). Would have been from a MEP-022 if it had said 400 Hertz there.
The Following User Says Thank You to EricWood For This Post:
Old 02-23-2017, 11:25:57 PM
Jim McIntyre's Avatar
^ right, and the regulator in it is one of the old non-electronic magnetic amplifier (akin to Onan's magneciter) types.
The Following User Says Thank You to Jim McIntyre For This Post:
Old 02-24-2017, 07:58:49 AM
Thanks all I am sure you are right I will be at my shop later and check it out.
There was some dirt, flaking paint and some corrosion so I sure I miss read it. Nice old vintage gauges can't believe none of the glass was broken.
If the moderators want to correct my original post to 5.0 from 50 k It is ok with me. Thanks all
Old 02-24-2017, 06:41:43 PM
Well after some careful cleaning I found that darn little dot between the 5 and the 0 it does say 5.0 Thanks for the tip
Onan 5.0CCRK-3cr/1r Control Board paridgerunner Onan Generators 11 10-15-2017 12:07:11 PM
Troubleshooting Control Board, Solenoid issues? Onan Genset BGE model:4BGEFA26100N jdecoarch Onan Generators 22 08-08-2015 11:25:03 AM
Onan 5.0cck-3cr/1r control board paridgerunner Onan Generators 3 03-02-2013 05:19:01 PM
Onan CCK Control board Ted_Cool Onan Generators 34 11-18-2012 10:56:31 PM
ONAN 4 CCK Control board wiring c east Onan Generators 3 05-02-2012 08:50:00 AM
