GE 45KW Generator
this thread has 26 replies and has been viewed 2706 times
Old 04-09-2017, 06:03:26 PM
25Eagle34 25Eagle34 is offline
Location: Auburn, CA. in the Sierra-Nevada Foothills on the way to Reno
Default Re: GE 45KW generator
If you can get me a TM number, I will search my inventory by sight as lost my listing of gen set manuals!
Don
Old 04-10-2017, 01:16:26 PM
Shade Shade is offline
Don
Unfortunately, I cannot even find a TM number, outside of TM 6115...
and I know that is not anything to go on. I have no additional information.
These manuals are harder to find than unobtanium...
Thanks,
So far the FSN and Model number are that have had any hits on information
but most of it ends in people in my same boat. I even call Sun Electric now
Snap-On, nobody there has any information. I think everything prior to
Snap-On buying Sun Electric in '91 was purged.
Old 04-12-2017, 06:50:30 PM
Thanks,
Was this gen set for the Army, Airforce, Navy or all of them . Find an Army Supply Base and they might be able to help you. I went through my gen set manuals and nothing.
Good luck!
Don
Thanks,
Make a web search for these two:
1. Where can you find older military technical manuals?
2. Where can you find older military generator Set Technical Manuals?
3. Look for Field Manual FM 21-6 as it lists all the military publications.
I did a quick search of 1 & 2 and there were several listings.
Good luck,
Don
Old 04-15-2017, 11:00:07 PM
Good luck!
Don
Good luck,
Don
Thanks for the leads.
It was a USMC unit not Army or AF.
The Following User Says Thank You to Shade For This Post:
  #25
Old 04-17-2017, 10:17:41 AM
Try the Marine CORPS Logistics Base, Barstow, CA, at: 760-517-6061. You will get the extension run around but try for the generator report section and they may be able to help you. Be sure you have all the gen set information
Several years ago, I needed a set of manual for my Marine Case 1150 Loader. They had a spare set of manuals free. They were very nice and cooperative.
The other source is the US National Achives but that is a very long and expensive process.
Good luck,
Don A
The Following User Says Thank You to 25Eagle34 For This Post:
  #26
Old 04-17-2017, 12:27:39 PM
Good luck,
Don A
Ron,
I have a microfilm listing of all the military generator sets by national Stock Number and TM number and nothing listed for your gen set. Sun must have just a few of that set.
Sorry and hope you find a TM in your search.
Don A
  #27
Old 04-24-2017, 09:38:07 PM
Default Re: GE 45KW Generator
Don, thanks a lot!!!
45kW Pincor Generator - Ford 300 propane / natural gas kww1184 Multi-Cylinder Stationary Engines and Power Units 56 05-12-2014 10:02:16 PM
pu703/g 45kw generator gtochuck Military MEP and Aircraft Gen-Sets 12 01-06-2014 07:45:48 PM
Need manual 45kw poinciana Onan Generators 10 11-18-2010 11:16:06 AM
Need help with PU-710G/711-g, 45kw gen set Lvillemedic Military MEP and Aircraft Gen-Sets 6 11-05-2010 06:49:30 PM
Need help with old(er) 45KW Delco gen set Bob Greene Generators & Electric Motors General Discussion 3 03-27-2006 01:23:41 PM
