My New PE-197
this thread has 36 replies and has been viewed 2879 times
Old 06-13-2017, 12:25:16 AM
macjeeper macjeeper is offline
Default Re: My new PE-197
I received this photo from another member for the exhaust door, interesting that the heat destroyed or made the instructions brittle over time....the battery door I'm still looking for it!
Old 06-13-2017, 12:49:32 AM
Found the remnants of what it used to show a miniature electrical schematic of the unit on the inside of the battery door, hope that helps, Mac
Name:	PE-197 Battery door electric schematics.jpg
Old 06-13-2017, 12:57:42 AM
Also on the outside opposite end near intake squirrel cage fan was the lubrication order as an attachment decal that was applied to the PE-197.
Also from another member of the group, Mac
ID:	284303   Click image for larger version
Old 06-14-2017, 02:30:51 AM
SPBiker SPBiker is offline
Thanks a lot Mac that really helps me a lot. Whoever owns that beauty is mighty lucky. Loving the original paint. Whoever painted mine silver painted over the lubrication order, mine was a silver "sticker" with black lettering, maybe not ww2 original. It looks like to me that the wiring diagram was a piece of paper cover with clear plastic?
Old 06-26-2017, 03:14:49 PM
Just started a major undertaking today. I'm working on getting the battery tray/ gas tank mount removed. In order to do so I had to remove the power panel. Here's a picture of my progress so far. If you ever have to do this the only piece of advice I can give you is to make sure to trace out the wires that need to be disconnected. The two that go into the generator, the wire that goes to the electronic choke, the thermostat, and another wire that goes to the Magneto are the only ones i had to disconnect
Old 06-28-2017, 01:52:30 AM
Must be nice to have a forklift available to lift 770 lbs.
Old 08-15-2017, 02:39:51 AM
Sorry guys, been busy and forgot to post my progress. I was able to get the panel off to remove the battery tray / fuel tank tray. I only sandblased the inside of the tray because the original paint on the bottom and back was still nice. I then sprayed it with red oxide primer and early war lusterless od for the fuel tank side and flat black for the battery side. I wasnt too happy with the olive drab color match, but I can always repaint later. I also made new cork strips for the fuel tank to sit on and for the tank strap
ID:	288660   Click image for larger version
ID:	288661   Click image for larger version
ID:	288662   Click image for larger version
Old 08-15-2017, 02:42:19 AM
Ive done the engine lift method and it is not fun or easy on the back. Why push and sweat when you can sit and ride
The Following User Says Thank You to SPBiker For This Post:
  #29
Old 12-23-2017, 06:38:57 PM
Santa came a couple days early with this NOS Hercules zxb head gasket. Does anybody know the torque specs for the head bolts?
Old 12-23-2017, 07:43:23 PM
Rich Mc Rich Mc is offline
This link gives shows the sequence and torque.
https://www.smokstak.com/forum/attac...1&d=1230853667
The Following 2 Users Say Thank You to Rich Mc For This Post:
