Frequently Asked MEP Questions
this thread has 5 replies and has been viewed 25175 times
Old 05-07-2008, 09:17:42 AM
Harry's Avatar
Images: 312
Default Frequently Asked MEP Questions
Check the F.A.Q. on our main generator board, for more MEP information: http://www.smokstak.com/forum/showthread.php?t=47155
Old 04-13-2010, 08:34:56 AM
K D Redd K D Redd is offline
Default Re: Frequently Asked Generator Questions
TO ANYONE LOOKING AT A MILITARY GENERATOR, IF IT HAS A FREQUENCY OF 400 HZ, THERE IS NO WAY IT CAN BE COVERTED TO 60 HZ. Consider it a source of engine parts for a 60 HZ military generator.
Kent
Old 11-09-2010, 07:57:02 PM
davey1000 davey1000 is offline
Default Re: Frequently Asked MEP Questions
Disagree disagree disagree! OK aircraft and military gensets may produce 400Hz but this is no big deal. In fact Stihl used to make a superb 3KW electric chainsaw that needed a 10KW "high cycle converter". A 400Hz 3 phase generator makes power that can be cheaply rectified into DC. (suitable silicon bridge rectifiers cost about £2 each or less, at least two will be needed) Once the 400Hz has been converted into DC it can be used "as is" for appliances with universal motors (motors with carbon brushes) or heaters (not fan heaters just the non-motorised "electric fires"). Unfortunately modern switches tend to be of the "AC only" type. The old fashioned switches which break the current with a large gap are needed. Some "classic" power tools such as old Kango hammers do have switches that break the current with a large gap so they should be OK on DC but on no account try to use DC to power a magnetic drill (the drill will be OK but the electromagnet will burn out)
If the use of DC is not to ones liking an inverter will be needed. The common type takes 12 volts DC from a car battery and uses a switched mode converter running at 50 kilohertz or more. The 50KHz AC is then rectified back to DC! The reason for doing this is to obtain a higher voltage DC of about 300 volts. The 300 volts is then "chopped" or "inverted" using thyristors in a bridge circuit. Danfoss make converters that turn 50Hz three phase AC into variable frequency AC and such converters are used by the thousand in factories as cheap standard 3 phase motors can be made to run at different speeds or even backwards!
Incidentally "dumm" universal motors such as power drills or angle grinders THAT DON'T HAVE VARIABLE SPEED should work fine on 400Hz provided that the voltage is approximately correct. 240 volt to 110 volt transformers designed for 50Hz should also be OK (although they will be needlessly heavy) Most laptop AC adapters should be OK on DC but the figure of 8 input plug may need to be reversed. Good luck!
Note that electricity can kill and can cause fires. Experiment at your own risk.
Old 09-11-2013, 09:43:46 AM
R Martin R Martin is offline
I have a MEP005AAS, the engine run great but no power, no Gauges working.
I need help finding a Manual and Possibly a service tech
Old 04-15-2018, 08:55:49 PM
Beachncountry Beachncountry is offline
I recently purchased a MEP-802A and discovered that it is missing the voltage regulator. The voltage regulator is made by technology research corporation however, they have quoted me an outrageously high price for the part. Obviously this is a very important part for the generator. Does anyone know where to get a new voltage regulator at a reasonable price?
The voltage regulator has eight wires that go to it. The wires have numbers on them. Does anyone know which wire goes to what terminal?
This generator was made in 2002 and shows that it only has 41 hours on it. I only saw the engine run briefly but visual inspection indicates that the 41 hours may be accurate. Any advice would be appreciated.
Old 04-15-2018, 11:05:21 PM
Email NOT Working
I could have sworn I answered this question already but I can't find it now. I would buy the voltage regulator listed as new on ebay. The price is in line with a regulator of this size and style and it will be so much easier than trying to retrofit something and having buildup issues or whatever. I speak from experience here.
edit:
Ah yes here it is. https://www.smokstak.com/forum/showp...56&postcount=5
Frequently Asked Generator Questions Harry Generators & Electric Motors General Discussion 26 02-27-2018 10:45:28 PM
Frequently Asked Kohler Questions Harry Kohler Generators 15 12-16-2017 01:35:45 PM
FREQUENTLY ASKED QUESTIONS on Onan Generators Harry Onan Generators 11 11-04-2010 01:51:34 AM
What I asked Santa for..... David Sundry Antique Engine Archives 2 12-25-2004 12:44:45 AM
I asked a smart guy about engines running too slow Mark Thompson Antique Engine Archives 5 01-05-2004 09:50:08 PM
