Jet Turbine Powered Generator
this thread has 21 replies and has been viewed 3486 times
Old 01-28-2016, 03:11:52 PM
JD840 JD840 is offline
Default Jet Turbine Powered Generator
Just aquired a Jet Turbine generator. The turbine is suppose to be the same as in the Chinook Helicopter. Anyone know the pre flight check list prior to first start. Its been sitting for 15 years covered looks like new was used for backup power shows 177 hours.
Old 01-28-2016, 09:28:20 PM
Default Re: Jet Turbine Powered Generator
Pictures, we need pictures! Been awhile since I've played with turbines, and its not like I was ever taught the proper ways, so.... First thing I'd do is change the oil, and yes you will need turbine oil. Second make sure the fuel shut-off solenoid is working. Get GOOD ear protection. Hit the start button, you have to hold it until it spools up to a certain rpm, when you hear it light off release the button, when it starts screaming don't run. Do not stand in the plane of rotation. After you shut it off do not be surprised if the PD and FD show up
Old 01-28-2016, 11:03:45 PM
pegasuspinto pegasuspinto is online now
Make sure you know what the output ratings are BEFORE you hook it up. Many Air Force generators are 400 hz output and just short of useless to the civilian world.
If you have a model# or something you could probably find a manual.
The Following User Says Thank You to pegasuspinto For This Post:
Old 01-29-2016, 12:36:29 AM
RichardR RichardR is offline
Make sure the batteries are adequate and well charged before trying to start it. The starter must spool the turbine up to a sufficient speed before light-off or else the air-fuel mixture will be too rich, leading to a "hot start" that can (possibly) damage the turbine.
The Following User Says Thank You to RichardR For This Post:
Old 01-29-2016, 08:20:22 AM
As mentioned above, plz learn everything about a turbine before you light it off. Find the TM (training manual) on it and digest it. I'm not the least bit familiar with it having only experience with Bell Long Rangers.
Hot start is something to be avoided as it will immediately cook and trash the engine. In the TM you'll learn if it has a hot start disable for protection. I don't know if it does. If not and always, keep an eye on the temperature as soon as the can (s) light off. That's the most critical time of operation. The other critical time is at shut down. Some engines must be idled a while for cool down before hitting the off button. It all should be in the TM with tables pertaining to altitude and ambient temps.
You'll learn first hand about what fuel consumption is! And yeah, a turbine is a different way to turn fuel directly into noise. Think of it as a single spinning part that can out noise a Detroit 2 cycle.
The Following 2 Users Say Thank You to I like oldstuff For This Post:
Old 01-29-2016, 10:51:55 AM
Thats sounds really fun! Cant wait. Thanks.
Old 04-06-2016, 09:02:56 PM
Ash fork genetator Ash fork genetator is offline
I saw one of these in operating condition at the Prescott (Az) antique auto club Watson lake car show swap meet and old engine fire up, a cpl years ago. It was the coolest (and loudest) generator that I've ever seen! A really awesome piece. Hope you get it to run, and survive to tell the story! Lol. a.f.g.
Old 04-07-2016, 12:10:25 AM
25Eagle34 25Eagle34 is offline
Location: Auburn, CA. in the Sierra-Nevada Foothills on the way to Reno
Please post the model, FSN or NSN, and the TM number if it is on the name plate. I may have A TM for it.
Old 04-07-2016, 12:52:21 PM
len k len k is offline
I've heard got to watch temps and rate of temp change or welds on blades crack. I've seen a car jet dragster, I looked in the back of jet and all the blades to outer ring welds were cracked.
Sounds like a fun toy, but between fuel consumption and if it's 400 hz, not really usefull. In aircraft it's likely more important to have light weight than good fuel consumption. On ground applications exactly the opposite is desired.
Old 04-07-2016, 01:03:53 PM
At a show several years ago, a gent came with a water pump that was turbine powered. Man did that sucker scream! Was neat to watch, but you needed ear protection if you were close to it. you could hear it a mile away! Literally!!! I would love to get a hold of one, but have not seen any for sale in my area.
Pyle National Turbine Generator Jon Rozevink Steam Stationary Engines, Traction Engines, Steam Boats 11 09-28-2010 08:20:59 AM
Info needed for a Pyle National X-2 steam turbine generator James L Steam Stationary Engines, Traction Engines, Steam Boats 4 10-16-2008 08:59:11 PM
INFO WANTED ON GAS TURBINE GENERATOR Denny Foster Antique Engine Archives 3 01-25-2004 11:44:55 PM
Moon Turbine Generator Allan Miloff Antique Engine Archives 0 03-29-2000 06:38:41 PM
Moon Steam Turbine generator Allan Miloff Antique Engine Archives 0 03-18-2000 06:45:49 PM
