MEP-805B won't start
this thread has 12 replies and has been viewed 3104 times
Old 04-19-2016, 11:50:32 AM
jamisonj jamisonj is offline
Default MEP-805B won't start
I just bought a MEP-805B gen and it turns over but won't start unless I use ether. I have primed everything. I believe it's a electrical issue. The R10 fault light is on. I can't find what that light means in any of the manuals. Does anyone have any idea?
Old 04-19-2016, 11:53:47 AM
Jim McIntyre's Avatar
Default Re: MEP-805B won't start
Once started, with the help of ether, does it continue to run, or die?
Old 04-19-2016, 12:31:08 PM
It dies after I stop the ether.
Old 04-19-2016, 10:22:32 PM
EricWood's Avatar
EricWood EricWood is offline
Where is this R10 fault lamp? (post a photo?) I don't see mention of it in the tech manual:
http://www.liberatedmanuals.com/TM-9-6115-671-14.pdf
Is this an LED, in a row of LEDs? There is a red Lamp 10 for overspeed condition, based on overspeed/out of tolerance MPU input, overspeed reset has been pushed, battery power has been reset.
Old 04-20-2016, 08:40:57 AM
Here is the Picture
Old 04-22-2016, 01:33:45 PM
dvan dvan is offline
I also picked up a 805b and 806b in Oklahoma City a month ago. There is a actuator on top of injection pump activating the fuel shutoff. My two generators would not turn them on and the speed control box seems to not be getting power. Temperarly I unplugged at injection pump and jump to battery to open fuel. I'm sure I have the issue you have
The Following User Says Thank You to dvan For This Post:
Old 04-26-2016, 05:02:20 PM
Have you came up with a perm solution? I purchased my gen at Oklahoma City as well.
Old 04-26-2016, 07:41:56 PM
I wired to the battery and it works. Sounds great. I need to figure out why it's not getting power.
Old 04-26-2016, 10:49:21 PM
EricWood's Avatar
Did you push the reset button on the speed control unit?
When you have it jumped/running, are any of the lights on the speed control unit lit? (DC Power, overspeed, crank terminate, speed sensor?)
Did you follow the link I previously posted to the the manual for your unit, or did you have a copy already.
Name:	805B Speed Unit.JPG
Old 05-01-2016, 12:17:12 AM
ID:	252713. Lights come on after its started. I've been in process of tracing it but can't find connecter P25 pin 9. And cannot find the wiring diagram FO-3.... I think it is a foldout in the operators manual which my manual does not have
MEP-805B won't start jamisonj Onan Generators 1 04-19-2016 10:21:06 AM
Onan 4k start/stop light doesnt work and stops running when release start switch JoshD Onan Generators 12 09-06-2014 07:51:40 AM
Onan 4.0CCK-Has rope start pulley. Can it start with electricity? Pete Spaco Onan Generators 8 12-18-2011 06:50:03 PM
Onan 5 CCK runs in hand start but not elec start ptschum Onan Generators 13 02-13-2011 07:50:45 AM
1913 IHC runs again throttle governing used John Deere H to start no bump start RobGill2008 Antique Gas Engine Discussion 1 08-17-2010 08:24:46 PM
