MEP 17a -2A042 -Onan 5KW- Resistor value in voltage controller
this thread has 13 replies and has been viewed 820 times
Old 01-22-2017, 01:43:52 PM
roelant roelant is offline
Default MEP 17a -2A042 -Onan 5KW- Resistor value in voltage controller
Dear Folks,
I have recently bought a mep 17 a generator, which is a bit of a rarety here in europe, and i am in the process of reviving it. After a lot of carb-cleaning and a rusted through oil filter top, i have now managed to get the engine running reasonably smoothly. It still has a few smaller issues like a rocker that someone grinded down, probably not being aware that this engine has hydraulic tappets..
Anyway, the reason i am looking for some help is my problem with the voltage regulator. After finding the generator does not produce more than about 45 volts I removed the voltage regulator from the set and found out it has a resistor that has fried...
In the doc i found on the internet it is stated that this generator should have a solid state regulator that has two transformers and a transistor end stage. On my (apparently a bit older ) mep 17a there is a different type of regulator. It has two smaller transformers ( one is actually a coil not a transformer) and a round transformer in a black casing with 8 connections. I believe this is a magneciter like type of regulator. It uses a 'magnetic amplifier' to regulate the power that goes to the field coil of the genny head.
I have not found a schematic of this regulator. Does anyone have this for me?
The fried resitor is R4 and my problem is that i cannot read the proper value of it anymore.
Any help on this problem would be very much appreciated.
I will include a picture of this regulator ( onan 305D316)
ID:	272985   Click image for larger version
Old 01-22-2017, 04:52:23 PM
Jim McIntyre's Avatar
Default Re: MEP 17a -2A042 -Onan 5KW- Resistor value in voltage controller
Yep - It's a mag amp. I have some of the 1.5 kW gensets in that family that use a similar regulator.
In fact, the tech manuals for the 1.5 kW gensets included the schematic for the mag amp AVR, but I just checked my 5 kW manual, and all it shows in the later electronic AVR.
You do know this can be replaced with an SX-460, right?
Oh, and Welcome to the forum!
Old 01-22-2017, 04:58:26 PM
Ah an answer allready, thats nice! So i should find that manual of the 1,5 kw version.. It is probably on the smokestak site somewhere....I will go find it..
Good to hear it can be replaced by a SX-460. Not sure how easy that is to find in europe for an affordable amount of money.
Thanks again for the info.
Old 01-22-2017, 08:13:33 PM
Well, I don't know how much help it will be. The 1.5 kW version, while similar, is a different item - designed for about 1/3 of the field drive power, I'd guess.
Chinese clones of the SX-460 are all over eBay for around 25 USD.
Old 01-23-2017, 12:31:18 AM
Vanman Vanman is offline
I don't know- a mag amp is an elegantly simple device. I'd want to replace the bad resistor before installing a complicated electronic circuit made out of Chinese components in its place.
Old 01-23-2017, 01:52:05 AM
I agree, but if the OP can't figure out the resistor value, and isn't able to reverse engineer it, the SX 460 is a viable option...
Old 01-23-2017, 05:12:42 AM
I have meanwhile found the schematic that was menitioned by Jim. It is basically the same diagram but not 100% the same. Actually ( bad luck) the resistor that is smoked is not in this diagram. The resistor that has burned out is in series with the field coil and has a zener parallel to it. I am not sure of the meaning of this setup. It might have something to do with getting the generator going on remenent magnetism.
I have found and ordered a sx460 on 'aliexpress'. ( aliexpress is a chinese web site that offers all sort of stuff , a bit like amazon) So it is a chinese version... It is very cheap but will take at least 3 weeks or so to arrive from china to the netherlands.
I am planning to connect a universal 0-30 volt (adjustable) lab power supply on e.g. 5 volt to the field just to check the generator to be alive..
Then i will wait for the sx460. I think it is an elegant solution, even if not 'original' to this genny.
Thanks again for help and advice..
Old 01-23-2017, 06:29:29 AM
Rich Mc Rich Mc is online now
You should try to determine what caused the resistor to fail. Is it a short in the field coil or over volt etc. The defect may damage the new AVR.
Old 01-23-2017, 06:40:26 AM
Thats a good tip. I will try out the gen head without the new regulator just supplying the field with a separate power supply. The current limiter on this power supply will tell me about a possible short in the field windings. anyone familiar with 'normal voltage and current' in this field coil during operation of the gen head?
Not knowing the actual functionallety of the fried resistor and zener pair makes it harder to trouble shoot the situation. I will check the zener to be alive. If not it is easy to understand the resistor blowing up....
Old 01-23-2017, 01:20:26 PM
Originally Posted by roelant View Post
...I am planning to connect a universal 0-30 volt (adjustable) lab power supply on e.g. 5 volt to the field just to check the generator to be alive..
Good idea. I don't know for sure, but the field drive is pretty low power - 5 or 10V at under an amp, I think. Are you going for 50Hz ? Might take a tad more drive. If so, that might be a hint as to the cause of the original magamp failure. There have been reports of sub-60Hz frequency burning up Onan's magneciter. The SX460 will be fine in this regard.
Then i will wait for the sx460. I think it is an elegant solution, even if not 'original' to this genny....
They're decent. Keep in mind that you might need to add some series resistance to your field winding, due to the SX460's minimum field resistance spec. Also, add a fuse somewhere, so if the SX460 fails, it's less likely to take your field winding with it...
Someone educate me about resistor and non resistor spark plug caps Motorhead Onan Generators 19 11-05-2016 08:17:41 PM
onan R1 resistor jeachen Onan Generators 6 12-13-2015 08:20:55 PM
Onan 4.0 cck resistor Coldshot Onan Generators 44 09-15-2012 05:28:59 PM
Onan voltage jump from 118 to 135 - 15 ohm resistor melts quarryman9 Onan Generators 1 10-29-2011 10:45:47 AM
Where is voltage regulator (controller?) on Onan 12.5Kw HDCAB Genset? fatshot Onan Generators 2 10-04-2010 01:36:07 AM
