PE-95K Won't Stop with Toggle Switch
this thread has 1 replies and has been viewed 453 times
Old 01-25-2017, 12:10:05 AM
coolpool coolpool is offline
Default PE-95K Won't Stop with Toggle Switch
The good news is the 1951 gen set I got in 2015 started right up after putting fresh fuel in it. The bad news is it wouldn't stop when I depressed the toggle switch down to stop and held it there. The toggle switch seems to be acting normal with plenty of spring tension up and down and all the wiring behind the panel is in good shape and tight. Is the 620.1 Stop relay prone to fail? Or am I out to lunch in suspecting that component. I will admit I'm weak on electrical and will need mentoring; but I do have a manual and a cell phone
Old 01-25-2017, 11:49:05 AM
25Eagle34 25Eagle34 is offline
Location: Auburn, CA. in the Sierra-Nevada Foothills on the way to Reno
Default Re: PE-95K Won't Stop with Toggle Switch
First check to make sure the toggle switch is good with a meter. Look at what else is in the circuit to check what component is not working to kill the engine. The manual should have the Starting/Kill circuit diagram.
Stop Switch not working? 7NHMFA26105A dillon Onan Generators 1 06-03-2016 09:33:58 PM
Onan MDJE 7.5 - Start Toggle Switch Problem Mikerob Onan Generators 5 02-07-2013 01:00:05 PM
Emergency stop switch kicks out when i push start switch hurdy Onan Generators 9 08-29-2012 07:50:51 AM
Onan 4.0CCK fuel pump prime using Stop side of Stop/Start switch? Magnetite Onan Generators 7 11-29-2011 10:31:10 AM
WICO stop switch gogo Magnetos, Ignition Coils and Spark Plugs 1 03-25-2009 03:02:49 PM
