MEP-701A Injector Removal
this thread has 6 replies and has been viewed 1059 times
Old 02-08-2017, 06:24:54 PM
malcom2073 malcom2073 is offline
Default MEP-701A Injector Removal
I have a 701A that I purchased (cheap) that runs terrible. I bought it for the generating head to refit it onto an exisintg motor, but I figured I'd give it a shot making it run right, since it only has 800 hours, maybe it's fixable.
I started to tear down the injection system piece by piece to ensure that everything is in good shape and replace where needed but I cannot for the life of me figure out how to remove the diesel injector itself.
The manual says to remove the fuel line, then retaining bolt, and then "remove the injector" I've tried prying on it with a tuning fork and a lever arm, but I'm afraid to put much more force on it (levered on a 12" fork with most of my weight) lest I break something.
Is there a trick to removing the injector? The picture in the manual showed the valve train removed... but the instructions did not specify that anything at all other than the retaining bolt and fuel line needed to be removed.
Thanks!
Old 02-12-2017, 12:29:41 AM
w7dms w7dms is offline
Default Re: MEP-701A Injector Removal
Thanks!
hi
had the same problem, lot of spray lub. plus some thinner. but i used a hammer working around about every 90*. start with taps and go from there. also used small pipe wrench on main body to turn it.
good luck
lloyd
Old 02-19-2017, 11:17:19 AM
Sorry for the delay, I'm going to be giving it a shot today and see if I can get it off. I've also discovered the return fuel line was rotted out, so I am heading into town to pick up a new rubber line, I will report back if I have any success with getting the injector out.
Old 02-19-2017, 12:50:08 PM
Tony Rye Tony Rye is offline
if you can get a old fuel line take the nut off braze a piece of 1/4 wire rope about 12 in on it take something small but heavy drill a 3/8 hole in it slide wire rope in hole braze other nut to that end you now have a slide hammer for inj. removal . i use wire rope because sometimes you can not get straight above the inj.
The Following User Says Thank You to Tony Rye For This Post:
Old 03-05-2017, 12:50:59 PM
Got it by just prying at it. The tip was pretty caked up, so I cleaned it off really good and reinstalled it, it runs slightly better but still not smooth. I need to make a good "clean space" and pull the injector completely apart and rebuild it. Thanks for the responses!
Old 05-07-2017, 11:53:21 AM
An update: I rebuilt the injector as best as I could on the bench, no real change in how it ran. I took off the valve cover and one of the lifters was loose so I re-clearanced them per the manual, put it back together, and it sounds like the piston is actually slapping the valve. Think I might have found why the lifter was loose haha. Might be a lifter bent or something worse... Unsure... but that motor is toast to me.
I'm going to remove the generating head to stick on another motor I have and probably sell the rest of the motor and frame as scrap. It was worth a shot for sure but I'm half thankful it didn't work out. I have an old Onan that I did a propane conversion on, and I've fallen in love with propane as a generator fuel.
Old 06-02-2017, 07:54:07 PM
I've got the genhead off and measured up for a bearing plate... Looks like it will work perfectly!
Anyone need any parts off the old diesel? I also have the frame and soundproofing kit. Doesn't seem that any locals have any interest in it... So figured I should offer here before I cash out for scrap, since parts tend to be hard to get.
The Following User Says Thank You to malcom2073 For This Post:
Onan DJ injector removal dfarr67 Onan Generators 5 05-05-2014 04:53:05 PM
Ruston CR injector removal. Greg Shipley Antique Gas Engine Discussion 2 01-17-2012 11:38:22 PM
injector removal tips robert d Antique Farm Tractors 4 07-30-2011 04:18:36 PM
SR2/Monarch injector removal Joseph Vintage Diesel and Oil Engines 1 05-08-2011 02:25:51 AM
DJx Injector removal Ted_Cool Onan Generators 4 04-17-2010 08:15:10 AM
