MEP 1800 rpm GASOLINE unit?
this thread has 21 replies and has been viewed 2049 times
Old 02-18-2017, 11:35:44 AM
Jim McIntyre's Avatar
Default Re: 1800 rpm GASOLINE unit?
Like David said, look for an Onan JB or JC set. These sets were well thought of enough to be the basis for the MEP-002 and MEP-003 Diesel sets.
I also agree w/ comments above that, for most purposes, the MEP sets are actually less reliable than a commercial/industrial quality set for at least two reasons: They have too many parts, and they have not been subject to the normal test and design evolution that has to occur for a projuct to be a success in the commercial marketplace.
The Onan JB/JC sets win on both fronts here.
Old 02-18-2017, 03:58:08 PM
nblack nblack is offline
Default Re: MEP 1800 rpm GASOLINE unit?
Agree with most of the previous posts. Another option. Find an old PU unit. (thinking PU-32c, or PU-286,<- although the latter starts getting overly complex) a PE 197 is a good serviceable unit, without being overly complex. All of these run little Herc' ZXA-ZXB variants, and are VERY quiet and reliable. Parts can still be had, when necessary. Waste heat can be gathered from them as well, adding to potential efficiency.
Old 02-18-2017, 11:49:00 PM
Deveak Deveak is offline
I'll look into some onan units instead than.
The only thing rarer than 1800 rpm gas units is water cooled. I haven't seen a single water cooled small engine for sale online anywhere. I'm sure someone is selling older models somewhere but the newer engines all seem to be aluminum air cooled garbage.
Old 02-18-2017, 11:58:18 PM
Email NOT Working
If you want water cooled, why not just grab some kind of car engine from a junk yard? Geo metro or something 3 or very small 4 cylinders.
Old 02-19-2017, 12:07:32 AM
Thought about it but thats a heck of a lot of work. I would do that if I could find a decently cheap way of governing the rpm. A nice large flywheel would go a long way in helping but I am not sure about how the engine would handle the weight. Could put it on a belted generator head and have the flywheel on the generator head shaft. Its hard to find anything these days built to last. If it does, it costs an arm and a leg or they dont sell to the public.
Old 02-19-2017, 11:21:04 PM
My advice is to keep your eyes peeled, and not to get in a hurry. I have found two PU-32C's for lesse.. first one was $250 and the second was about $300 (with shipping?) Or, If you don't need a lot of power, the old M5's have a 6 pole head and turn at 1200prm, and are water-cooled as well. (simple, and same 'Herc engine). Tell you what- I also have a trailer mounted RJC (with fuel tank) 12kw that I picked up for $300. Deals can be had. C/L is your friend, and like I said. Patience.
Good luck
Old 02-20-2017, 12:17:00 AM
Good luck
1200 you say? Sounds even better but how hard is it to find parts?
Also how is the power quality?
Old 07-18-2017, 09:32:03 PM
Hello!
Sorry for the late reply. Have been travelling, and then trying to get caught up on things around the homestead when I get home, amidst sciatica problems. With regards to parts availability: IF (and it is a BIG IF) I needed parts for the old M5's I would either scavenge parts from another unit ( these things breed out of control), OR I would contact Jerry Biro at Hercano propulsion for(engine) parts. OR would buy their simple parts from some seller on the internet. Note: There is also currently some idiot on epay that is trying to sell parts from one for RIDICULOUS $$$, and as far as I can tell, nothing has sold in months.- he keeps relisting them, and the price is coming more in line with reality. (i.e. cheap). OK. power quality. from an M-5, remember, you are only going to get around 16-20amps per leg, but it should be smooth, reliable power. Also, point of note: the carburetor parts can be had from McDonald carb and magneto, OR!! you can replace the carb with an old B&S carb, and usually get better fuel burn rates than the original Schebler carb (that some real idiots think is worth $$$ (only worth $50 with shipping)). I have tested one of these units under load for several hours, and achieved an unloaded burn rate of .5 gal/ hr. The original carb yielded 1 gallon/hr. regards,
Noel
Old 07-26-2017, 07:46:52 AM
Esteban32696 Esteban32696 is offline
I also suggest going with an older Onan . I have a 1968 Onan 2.5 KW for simple back-up in " Hurricanado Florida. " It is a 1968 , 1800 rpm, & still does the job !!
Old 07-27-2017, 04:54:16 PM
John Newman, Jr.'s Avatar
How much power do you want? If you can get by with 3000 watts, Onan made a beautiful set called the W2C. Water cooled, twin cylinder inline all cast iron engine that runs at 1800 RPM. Streamlined / Deco styling too!
You need one (or more)
John Newman, Jr.
Saint Louis, MO
I Can Probably Fix That
International Harvester Gas & Gasoline Engines (1-50hp) & Gasoline tractors 12-45 hp TractorDom Antique Gas Engine Discussion 1 11-21-2015 07:09:42 PM
1800 RPM unit. Never run. pcrmike Onan Generators 15 10-26-2010 03:28:43 PM
Do ALL Onans run at 1800? harwill Onan Generators 6 08-12-2010 11:15:27 AM
Wanted: 1800 rpm Alternator Jim McIntyre Generators & Electric Motors General Discussion 7 09-15-2004 06:10:17 PM
1800 WATT ALTENATOR. SLANDROW Generators & Electric Motors General Discussion 2 03-19-2004 11:42:21 PM
