MEP26A to the rescue
this thread has 4 replies and has been viewed 826 times
Old 04-13-2017, 09:52:10 AM
Carter Carter is offline
Default MEP26A to the rescue
After trying to start the truck found I had left the battery ground solenoid in the on position for several weeks and batteries were so dead that my new 24v charger had no effect after sitting for many hours. Hmmm, what to do now? then I decided to try my new to me 1968 generator which makes 28vdc at 105 amps. The set started after 4 pulls of the rope then It ran until warmed up then I connected the slave cables to the drivers side receptacle turned on the gen sets circuit breaker and the truck fired easily with no noticeable strain on the set and it's little 4 cyl. engine. Shut the unit down but left the T245 running until the volt meter showed the indicator in the green. Worked like I had hoped when I bought the set last Aberdeen Rally for $250 with only 188 showing on the Hobbs meter.
The Following 2 Users Say Thank You to Carter For This Post:
Old 04-14-2017, 07:57:07 AM
Esteban32696 Esteban32696 is offline
Default Re: MEP26A to the rescue
Good deal !
Old 04-15-2017, 08:27:49 AM
That was the reason I bought it the set. The Dodge, a 1953 M37, has a 24VDC electrical system that charges it's batteries at 28 V.
Old 04-15-2017, 11:10:06 AM
coolpool coolpool is offline
I always wondered if My PE-95K would start my 24V M38 Cdn Jeep, now I know! Very nice M37 BTW
Old 04-15-2017, 01:33:53 PM
I once owned a PE95K and the only 24V generated is by the exciter generator/starter and I do not believe it produces enough amps to spin over the M38s engine. My set as stated makes 105 amps and was designed to accept a very heavy load.
The Following User Says Thank You to Carter For This Post:
The Rescue of the Day Brothers Clemens Smokstak Down Under 1 10-21-2016 09:21:45 AM
Wisconsin Rescue? cancunia Wisconsin Engines 6 12-28-2015 08:46:11 PM
River Rescue? Rick Mannen Steam Stationary Engines, Traction Engines, Steam Boats 33 06-06-2015 02:28:06 PM
Rescue the Fire Rescue Truck ESU9 Onan Generators 0 03-11-2010 12:33:44 PM
