Help with ID. Wis VG4D with Lema gen head
this thread has 12 replies and has been viewed 834 times
Old 05-31-2017, 07:34:42 AM
iceman iceman is offline
Default Help with ID. Wis VG4D with Lema gen head
Just found this military 10 Kw generator with Wisconsin VG4D with a Lema Generator end. What I do know is that it has a built in transfer system. I removed the side covers to take photos. Looked it all over and I didn't find any "ID" tag. I would like to know the Model # of this genset. Any help would be fantastic.
Thanks Kieth
ID:	283331   Click image for larger version
ID:	283332   Click image for larger version
ID:	283333   Click image for larger version
Old 05-31-2017, 07:38:39 AM
Default Re: Help with ID. Wis VG4D with Lema gen head
Here are 4 more photos.
ID:	283335   Click image for larger version
ID:	283336   Click image for larger version
ID:	283337   Click image for larger version
Old 05-31-2017, 07:55:19 AM
I'm no help to you other than the comment omygod what complexity!
Good luck with that one. The TM has to be 2 inches thick if you can find one.
Old 05-31-2017, 10:18:56 PM
w7dms w7dms is offline
i think it is a EMU 10. 10 kw. used by air force and air guard units. the control units were a "PITA"
The Following User Says Thank You to w7dms For This Post:
Old 05-31-2017, 10:39:33 PM
moteurdelco moteurdelco is offline
WINPOWER were using a vH4d with their 10-12 kw. A vg4d can run more kw,;at 10kw ''il ronronne''!
The Following User Says Thank You to moteurdelco For This Post:
Old 06-01-2017, 12:03:21 AM
Vanman Vanman is online now
Well, I for one LOVE that control panel! As long as there are no electronics anxiously waiting to fail, I'd love the whole thing.
Keith
Old 06-02-2017, 07:52:24 AM
Thanks for the info. I'll try to look up that model number.
Does anybody have a genset like this?
Kieth
Old 06-25-2017, 01:00:28 PM
bmwsyc bmwsyc is offline
Yup, thats an EMU-10. I also have one that runs. Mine is from 1968. They are Air Force generators made by Consolidated Diesel Electric Corp (or company). I have only seen one other on Craig's List in Florida. I have been looking for manuals for years with no luck. I would love to have a new one with manuals. The VG4D is slightly different from the civilian version, but close enough. Engine manual is easy to find, but for the whole unit...never had any luck.
If you have questions, I'll try to help. You don't by chance have any literature?
The Following User Says Thank You to bmwsyc For This Post:
Old 06-26-2017, 08:57:00 AM
25Eagle34 25Eagle34 is offline
Location: Auburn, CA. in the Sierra-Nevada Foothills on the way to Reno
Do you have a National NSN or Federal FSN number which starts with 6115 and will make Search to see if I have a manual in my collection of over 2,000 manuals.
Try: militarymanuals.com as they list a number of generator manuals listed-- Good Luck
Old 06-26-2017, 05:27:31 PM
The Air Force was kind enough to stencil the NSN on the outside.
6115 00 719 6122
Old 06-26-2017, 08:15:37 PM
Did they put the TM number on also?
Old 06-27-2017, 12:10:14 PM
No, and I have not been able to figure out a TM or TO number.
Old 06-27-2017, 12:46:58 PM
Check With Robbins and Wright-Patterson Air Force Bases to see if they can help finding a manual.
VG4D Help! BreezyRidge Repair Wisconsin Engines 2 07-20-2015 09:25:15 AM
Lister Project -- Question about LEMA generator Head cjbaum Vintage Diesel and Oil Engines 6 10-31-2014 10:23:06 PM
need help with lp on vg4d jammer28 Kohler Generators 6 03-23-2013 04:27:48 PM
VG4D Head bolt grade VG4D Wisconsin Engines 5 12-06-2012 01:14:32 PM
VG4D Head VG4D Wisconsin Engines 8 10-26-2012 02:12:43 PM
