Mep 806a
this thread has 3 replies and has been viewed 737 times
Old 06-10-2017, 11:27:33 AM
Billy J Shafer's Avatar
Default Mep 806a -1612
Hey Guys
I have an issue with my 1612. Both seem to be having the exact same issue. Briefly describing, I am getting 24 volts at the shunt in the panel. After that I am getting volts nowhere else in the panel. Generators wont start turn over or anything. The TO states to check R14, and it should be reading 70, but ohms is only showing 40. I am at a loss as to what the issue could be. It almost seems like there is something so simple we are overcomplicating and not thinking through. ANY HELP!
I will post update or answer any questions you may have.
Last edited by BTPost; 06-10-2017 at 12:06:13 PM. Reason: Sorry Billy, Got this messed up doing Forum Cleanup
Old 06-10-2017, 12:10:35 PM
BTPost's Avatar
BTPost BTPost is offline
Images: 1
Talking Re: Mep 806a
This post was originally posted by Maccock84, and I messed it all up while doing Forum Cleanup.... Please only Post ONE Thread, about any ONE Unit, in just ONE Forum... It will get plenty of Play....
BTPost Chief Moderator
Bruce in alaska
Old 06-10-2017, 12:57:56 PM
madcock84 madcock84 is offline
Default Re: Mep 806a
Sorry about that.
Any help is greatly appreciated.
The Following User Says Thank You to madcock84 For This Post:
Old 06-12-2017, 10:28:38 PM
Richard L Richard L is offline
I am not familiar with these units, but when you say you are getting voltage to your shunt, is there voltage at both sides or terminals? If not try touching a jumper across the shunt and see if you get power.If a shunt gets too hot it will act like a fuse.
Like I said I am only shooting from the hip.
R
MEP-806A Feild flash issue? R Racing Military MEP and Aircraft Gen-Sets 1 06-14-2015 04:30:27 PM
