PE-75 Carrying Handles
this thread has 10 replies and has been viewed 632 times
Old 09-01-2017, 05:29:27 PM
Myers Myers is offline
Default PE-75 Carrying Handles
Does anyone happen to have an original set of PE-75 carrying handles? If so, would you mind sending me the measurements? My 75-U is missing its original wood handles, and I would like to make a set of replacements. I know I could eye ball it and be pretty close, but I'd rather go off of the correct measurements.
Old 09-02-2017, 12:30:38 AM
K-Tron K-Tron is online now
Default Re: PE-75 Carrying Handles
On Monday I should be able to get you some pictures and dimensions of the handles you need for your PE-75. I have actually never removed them from the factory skid. It is hard to tell how they come out. I wouldnt want to be the soldier that had to carry that sucker across the field. It is deceptively heavy!
Chris
Old 09-02-2017, 12:12:51 PM
Hi Chris,
Thanks for helping out. I know they are 1.25" red oak dowel rods, I just need the correct length. I was hoping to make them this weekend, so if anyone else has the measurement handy, I would appreciate it. If not, I can wait until Monday just the same.
I agree on the weight! I had to remove mine from the back of a 1944 GPW, and ended up having to take it apart in order to remove. Engine, skid, and then the generator haha.
Old 09-03-2017, 11:09:33 PM
w7dms w7dms is offline
on my unit the handles are 26 1/2 in.
Lloyd
The Following User Says Thank You to w7dms For This Post:
Old 09-03-2017, 11:47:39 PM
Motormowers's Avatar
Chris
Chris that was meant to be carried by 4 soldiers thats why they have 4 dowels. One would surely need a hernia operation after moving it a few times LOL
When life hands you lemons. Make pizza with it and have the haters wonder how you did it.
Old 09-04-2017, 10:14:42 AM
Thanks, Lloyd!!
Just out of curiosity, which model of PE-75 do you own?
Old 09-04-2017, 04:07:01 PM
Do you have a later PE-75? I measured mine again and 26.5" wouldn't even fit between the brackets, 25.5" looks just about perfect though.
Old 09-04-2017, 05:17:10 PM
25Eagle34 25Eagle34 is offline
Location: Auburn, CA. in the Sierra-Nevada Foothills on the way to Reno
My TM 11-900A, PE-75-AF, August 1952 states handle are made of Hardwood, 25-1/2" long and 1-1/8" diameter.
You should be able to measure the length also were they are stored on the belt side of the frame.
Old 09-06-2017, 01:34:06 PM
Finished the handles today. I had guessed they were 25.5" long, but am glad I was able to confirm before I made my own. Thanks again for the help.
ID:	290563   Click image for larger version
ID:	290564   Click image for larger version
ID:	290565   Click image for larger version
The Following User Says Thank You to Myers For This Post:
Old 09-06-2017, 04:10:35 PM
I am sorry for the late reply. I am measuring right at 25-1/4" in overall handle length on my PE-75-AD, and right at 25-3/4" between the vertical channels which keep the handles in place. The original handles are 1-1/8" o.d., and are rounded over on each end. Your PE-75 frame and handles turned out great! If you need any more pictures/measurements let me know.
Chris
Old 09-06-2017, 11:07:46 PM
i rechecked my unit the handles are 25 7/8 long. i used a hf tape the first time!
it is AE unit. but not oem has a wisconsin AENTD with 12 volt starter.
Lloyd
Associated Starting Handles LarrapMan Antique Gas Engine Discussion 3 07-11-2013 08:52:41 PM
Crank Handles yea or nay!!! Denny Foster Antique Gas Engine Discussion 98 12-04-2012 09:53:22 PM
Crank handles for? Wildcat Antique Gas Engine Discussion 10 11-28-2011 07:28:25 PM
Bundle Fork Handles Meco3hp Farm + Industrial Antiques and Collectibles 0 07-18-2010 07:28:20 PM
handles for reel mower Sky Antique Gas Engine Discussion 0 08-06-2006 10:58:14 AM
