Shop backup power generator
this thread has 5 replies and has been viewed 776 times
Old 09-03-2017, 01:47:09 AM
84prerunner 84prerunner is offline
Default Shop backup power generator
New to these old military generators, never been around one at all. I have a fair amount of tinkering and repairing on small generators and a basic understanding of how the systems work, but thats about it. I have spent a few hours reading on this forum, but the amount of info is overwhelming off the start.
Here is the deal. A friend of mine has a chunk of property with his house, guest house and a large shop full of fabrication equipment (welders etc). During power outages we have ran the shop off a 10kw Ranger 250 generator, does a decent job as long as the air compressor and multiple welders aren't all going at once but that still leaves both houses without power. He now wants to add a big diesel generator that can run the whole compound. I am thinking he will need something around 30kw to run the central AC plus all the other loads.
Will a military surplus generator be a good fit for this job? longest power outage in the last few years has only been 14hrs. 1-2 times a year it seems to go out for 2-6hrs. so basically a bigger generator isnt really needed, but he wants it so im not going to say no. what is everyones opinions on this?
Old 09-03-2017, 07:58:06 AM
dependable dependable is online now
Default Re: Shop backup power generator
I think military surplus is a good way to go, 1. If you are willing to take a chance on buying an untested machine at auction. 2. If you can do your own work on it, they usually need a least a little work to get going.
If the above are true, you can get a well built often low hour machine for a fraction of the cost of a new 1800 RPM commercial unit. Or you can find one someone has already gone over it for more $, then the price might be closer to that of a used commercial unit.
Old 09-03-2017, 10:44:15 AM
OrgWayne OrgWayne is offline
Hay 84 , check out sewerzuk on you tube , he does or did all lot with mil MEPs
and has some good info on where to get them and fix them up
Wayne
Old 09-03-2017, 12:56:12 PM
Be aware that most military sets in that size range are 120/208 or 240/416 voltage, not the typical 120/240 that most residential services are.
FWIW, my house/shop will run fine on 120/208, but your situation may be different.
Old 09-03-2017, 03:23:58 PM
AlexV AlexV is offline
I just learned about them too from this forum. I've been checking out a few MEP-803a on E-bay. The prices look good. Some review's I've read said to stay away from them because the military generators are over complicated and parts are hard to come by. A few of the reviews said an older diesel Onan is a much better choice.
Old 09-04-2017, 10:50:48 AM
Birken Vogt Birken Vogt is online now
Email NOT Working
These old ones are usually not too hard to convert to single phase or even delta (or both) but they usually have an obsolete engine like a White or Continental or Allis-Chalmers and incredibly complicated controls and high prices for what they are. I would rather have a Cummins with Power Command than one of these things....
Onan 4.0CCK-3cr backup power for well pump tparr Onan Generators 47 01-02-2017 09:56:07 PM
Onan 6.5NHE Genset removed from RV, setting up as House backup power mobilemedic01 Onan Generators 12 08-09-2013 10:35:10 AM
Home power backup jlt Onan Generators 7 09-17-2012 09:49:07 PM
Kohler generator for home backup power wyM1Aguy Kohler Generators 4 01-29-2010 09:01:03 PM
Best diesel genset for backup power Robert Cousins Generators & Electric Motors General Discussion 16 08-06-2006 08:13:26 PM
