MEP 003a Engine Repurposed
this thread has 2 replies and has been viewed 823 times
Old 09-11-2017, 12:23:22 PM
cnicholls cnicholls is offline
Talking MEP 003a Engine Repurposed
Hello, I am new here. From what I have found after Googling for 8 hours, this site has the most knowledge about the Onan Genset engines (among tons of other things).
After a impulse buy years ago, I ended up with one 002A and three 003A engines only (no gen set) they look new, with caps on exhaust and inlets the flywheels don't look like they have ever been mated to anything. With fresh(ish) paint.
Has anyone heard of someone using 003A for anything other than a GenSet?
I would love to put this in a low speed buggy or a hydraulic pump driver.
I am always building/recycling old iron for use around our property
If anyone has any input on how to adapt the engines to a straight shaft, pulley/sprocket, or clutch/flywheel I would be very greatfull.
First let me contribute to future googlers, Here is some info that may save you time.
This is what I know at this point about the. MEP 003A Engine based on MIL-STD-1410
MIL SPEC Horsepower: 20 @ 1800 RPM.
No. of cyl: 4 (4 Cycle)
24 VDC electric start
Operating speed: 1800 RPM
140 CI (2294 CC)
19:1 compression ratio
Air Cooled/Naturally Aspirated
5.5 quarts oil
Fuel Consumption: 1.09 gph at rated load.
Environment: Minus 25° F (-31.7° C) to plus 107° F (+41.7° C)
Counter Clockwise rotation
SAE 4 bell housing
Bell housing Od: 15 7/8in
Bell housing ID: 14 1/4 12 studs 3/8 studs
bolt circle: 15in
Flywheel is: I have yet to find out if the flywheel is sae, or custom.
12 3/8 OD
10 1/8in bolt circle - 4 sets of dual bolt holes
Governor: Internal Flyball Externally adjustable.
My understanding is that the GOV HP Rating is:
80% of 1/2 MFG Rating
GOV HP 20 = 80% of 25 (1/2 MFHP)
Making the engine 50HP@1800RPM Manufacture Spec?
Also, advice like "sell the engines and buy something else", I have read enough of those opinions on these forums thanks, I have already read your point of view.
I am a skilled fabricator feel confident that I can overcome the challenge.
Old 09-12-2017, 07:42:13 AM
dependable dependable is offline
Default Re: MEP 003a Engine Repurposed
There was a long thread like this on the Steelsoldiers military site a few years back. Suggestions of mini bikes, go carts, but it is a slow revving motor designed mainly for continuous duty at that 1800 RPM, loud, relatively heavy. Good fuel economy though. Lots of suggestions, jokes, but I don't remember if anyone ever actually built anything.
They would be good for running pumps, etc, one of their only other official uses was hydraulics for a type of anti aircraft installation.
They are over speced some, maybe 30 %, but will not make 50 HP. You would get the best money for it selling to a MEP-003a owner, there are quite a few out there.
Old 09-12-2017, 08:20:19 AM
CharlieB CharlieB is offline
Google "Tapered shaft adapter." Easy fix.
Check engine design to determine if it can support the side loading of a belt or chain drive, or if an external shaft bearing will be needed.
ONAN MEP-003A engine conversion to clutch Sousakerry Onan Generators 3 02-23-2017 09:54:36 AM
Need DJC / MEP-003a engine advice Isaac-1 Onan Generators 3 03-24-2016 11:16:17 AM
MEP 003A no power engine starts and runs good. Ed ke6bnl Military MEP and Aircraft Gen-Sets 8 12-21-2015 04:44:13 PM
MEP-003a / DJC engine question Isaac-1 Onan Generators 11 04-27-2014 08:32:01 PM
Repurposed Materials PTSideshow Machine Shop and Tool Talk 1 11-19-2011 08:53:18 AM
