John Deere Disk plow
this thread has 4 replies and has been viewed 1037 times
Old 06-03-2015, 07:08:04 PM
Wayne Riedlinger Wayne Riedlinger is offline
Default John Deere Disk plow
Today I pulled this disk plow out of the line, I loosened a few things and tightend a few things greased and oiled any thing that moves on it then headed out to the dandelion field to try it out. I have no idea when this was last used but probably 40 or 50 years ago. I have never seen a disk plow work before but I like the way it works .it was a nice load for the old AR in second gear.
ID:	226852   Click image for larger version
ID:	226853   Click image for larger version
Old 06-03-2015, 07:27:45 PM
Heins Heins is offline
Default Re: John Deere Disk plow
I would think the tail wheel should follow the furrow the last disc makes.
Old 06-03-2015, 08:47:07 PM
The ground here this year is very dry and hard so it tends to roll out and to the side sometimes. In some places in the field there is no moisture in the ground at all.
Old 06-03-2015, 08:51:23 PM
lukeste lukeste is offline
Images: 1
The few organic farmers down here like those for turning over quack grass and dandelions, more than regular plows. Bet the ar sounded pretty sweet. Thx for the pics
Old 06-03-2015, 10:07:10 PM
Caleb Carpenter Caleb Carpenter is offline
Images: 1
They are also called dryland plows because they will go in the ground when nothing else will. Setting a disc plow properly is art form. They have ton of side draft and if it trying to run beside you need more weight and need to adjust the angle of the wheels and probably the hitch.
I have some literature some where that tells the differences in setting molboards, oneways, and discplows.
Looks like a good time!
The Following User Says Thank You to Caleb Carpenter For This Post:
Farmall Super H with IH three disk semi mount plow Pat Bayer Antique Farm Tractors 7 02-28-2017 04:13:58 PM
Have old John Deere plow, where are all you old plow experts? lowflyer Horse Drawn Equipment 14 04-12-2015 12:57:30 AM
John Deere A, plow A3 2 way plow information needed Johnny D 1837 Antique Farm Tractors 3 05-21-2013 07:39:52 PM
John Deere Disk plough Amosalmo Horse Drawn Equipment 5 07-08-2012 12:48:39 AM
John Deere NO-45C plow oldjdinterest Farm + Industrial Antiques and Collectibles 4 12-22-2010 03:21:16 PM
