Homelite 23A Fuel Filter
this thread has 1 replies and has been viewed 474 times
Old 01-16-2018, 02:03:05 PM
Ed Stoller Ed Stoller is offline
Default Homelite 23A Fuel Filter
Yesterdays task was to clean the fuel tank which had a cup of rust in it and required removing it from the unit to clean it. I discovered this brass casting on the bottom and initially did not know what it was.
See picture.
It had a cap on the end which I removed and found the cavity packed with rust and unearth the remains of a spring. Next a disk came out. Behind the disk was some kind of material which I dug out with a screw driver. I concluded it was filter material because the cavity opened to the bottom of the fuel tank. At the end of the cavity was a wall with three holes in the center. These holes lined up with the center of the filter material and led to the fuel pick up reservoir.
I took the filter element out of a new inline filter and found a suitable new spring for replacements.
Does anybody have any tech data for the Homelite 23A?
Old 01-16-2018, 07:53:58 PM
s100 s100 is offline
Default Re: Homelite 23A Fuel Filter
As stated in response to your earlier post, get a copy of "Small Engine Service Manual". It's about the only source of information on these engines. My copy is 9th edition I think and dated 1969. Bought it new back then. It's paid for itself time and time again. Now to find a copy you need to go to a good used book store or everyone's most hated online auction site, whose name I shall not utter.
L634 Fuel Line Fitting Type Between Fuel Filter and Pump? Birken Vogt Onan Generators 4 08-22-2015 06:38:07 AM
Onan MEP 016B Military Fuel Filter & Air Filter (Help) Doogdoog Onan Generators 12 08-17-2015 07:38:11 PM
Onan CCK Fuel Filter jnjvan Onan Generators 8 11-19-2014 08:49:47 PM
Fuel Filter egreydove Antique Gas Engine Discussion 4 04-04-2010 08:28:24 PM
TD-40 Fuel Filter 20 Reeves Highwheeler Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 1 06-22-2006 08:26:14 PM
