Lunkenheimer No. 3 Fig. 1300 Sentinel Oiler
this thread has 3 replies and has been viewed 2563 times
Old 08-27-2013, 08:43:54 PM
jboyer1028 jboyer1028 is offline
Default Lunkenheimer No. 3 Fig. 1300 Sentinel Oiler
What do the information mean on the Lunkenheimer oiler?
No. 3
Fig. 1300
Sentinel
Jeff
Old 08-27-2013, 09:31:17 PM
Mike Monnier's Avatar
Hoarder
Default Re: Lunkenheimer No. 3 Fig. 1300 Sentinel Oiler
#3 is the size of the oiler. Sentinel is its identifying name. The Paragon is nearly identical except that it has a check ball in the base and a vent tube for cylinder use. The Fig. 1300 is basically a catalog number to identify later Lunkenheimer oilers. The early models just used the name. Hope this helps.
The Following User Says Thank You to Mike Monnier For This Post:
Old 08-27-2013, 09:43:29 PM
Doug Kimball's Avatar
Images: 78
I believe the Sentinel uses brass stampings; the Paragon uses brass castings. Paragon has swiveling cast fill; Sentinel a threaded plug. Paragon much higher quality.
In Kennebunk, Maine;
Doug Kimball
Old 08-27-2013, 10:15:20 PM
Rob Charles Rob Charles is online now
Card Sponsor
Both the early and late sentinals(heavy pattern and 1300 series)use brass castings. The 1300 series is a little lighter and simpler.A well made oiler for machine bearing use.Rob
The Following User Says Thank You to Rob Charles For This Post:
Lunkenheimer Mars Oiler ? amazinghistory Steam Stationary Engines, Traction Engines, Steam Boats 2 04-24-2012 11:13:39 PM
Lunkenheimer oiler Rag Antique Gas Engine Discussion 5 10-14-2008 10:46:45 AM
Lunkenheimer Mars #4 Oiler Ralph Leonard Antique Gas Engine Discussion 4 01-25-2007 01:22:27 AM
Lunkenheimer Paragon Oiler Jim Stigerwalt Antique Gas Engine Discussion 3 06-15-2005 09:41:40 PM
Lunkenheimer oiler Glenn Karch Antique Engine Archives 1 10-27-2002 12:04:56 AM
