1/2 pipe thread plug adapter
this thread has 12 replies and has been viewed 1830 times
Old 01-05-2016, 03:07:58 PM
Walter Neumann jr Walter Neumann jr is offline
Default Re: 1/2 pipe thread plug adapter
at 15dollars a set they are not worth making
Old 01-06-2016, 10:41:56 PM
Tom G Tom G is offline
Originally Posted by Steve Kunz View Post
From what I understand the 14mm spark plug thread is a special pitch at 1.25mm and a regular 14mm tap is 1.5mm pitch??
Here is a link for premade one's for model T Fords.
https://www.modeltford.com/item/14MM-AD.aspx
Available from Sears. What's your problem?
http://www.sears.com/irwin-hanson-vi...2&blockType=G2
The Following User Says Thank You to Tom G For This Post:
Old 01-09-2016, 12:22:11 AM
cobbadog cobbadog is offline
Hi Steve Kunz,
with the metric pitch both 1.25mm and 1.5mm are standard options, I have them both for many different sizes in my garage.
It is like the different of UNF & UNC or BSF & BSW it is a coarse and fine thread option for different applications.
Hope this helps.
pipe thread cutting TomBall Machine Shop and Tool Talk 18 07-25-2015 01:07:19 PM
3/4 inch pipe thread spark plug REB37E Magnetos, Ignition Coils and Spark Plugs 10 07-23-2014 08:42:16 AM
Spark plug adapter... Jim Sherman Antique Gas Engine Discussion 1 11-06-2011 02:35:59 PM
Adapter to go from 1" pipe thread to regular exhaust pipe? LombardiniDiesel Small Air Cooled Gasoline Engines 2 02-07-2011 12:15:00 AM
PRIMING CUP 1/4 inch pipe thread Eric McKenna Antique Gas Engine Discussion 3 07-24-2010 09:35:16 PM
