Go Back   SmokStak > SmokStak® Vintage Electrical Equipment > Generators & Electric Motors General Discussion > Generac Generators (SEARS, etc.)
Generac Generators (SEARS, etc.) Restoring, maintaining and operating Generac generators.
Generac 15 KW coil replacement
this thread has 4 replies and has been viewed 239 times
Old 01-09-2019, 02:53:10 PM
NH Sparky NH Sparky is offline
Default Generac 15 KW coil replacement
Hello, I have a customer with a Generac 15 KW standby generator, Model # 0043903. S/N 4214749
The spark plug wire has suffered rodent damage where it exits the flywheel cover on it's way to the spark plug on the operators side of the generator. There are two different part numbers for the 2 coils based on cylinder number. I don't know which of the 2 cylinders is #1, so I don't know which coil to order. According the the parts list, cyl. 1 coil P/N is 0C3052 and cyl. 2 coil p/n is 0E7743.
Any insight as to which cylinder is #1 would be much appreciated.
Thanks
Dave
Old 01-09-2019, 06:06:45 PM
Bassplayer1985 Bassplayer1985 is offline
Default Re: Generac 15 KW coil replacement
Thanks
Dave
Cylinder #1 is the one on the starter motor side. so this one would be furthest away from you if you are looking at the machine with the lid open. Basically its the harder one to get to. If you look at the flywheel straight at, its the one to the right of it.
Old 01-11-2019, 02:24:07 PM
Gentek Gentek is offline
Be aware though that the ignition coils should ALWAYS be replaced in pairs as well as the old ground wire with the diodes in it. The new coils have integrated diodes and won't work correctly otherwise. If you need more info, PM me here and I would be happy to help!
Old 01-16-2019, 09:54:32 AM
Thanks for the response and info. As per Gentek's advice, I'll replace both coils. I am definitely going to wait until spring when its warmer though!
I was able to pull what little slack there was in the plug wire out far enough to stop it from shorting out, but it's a poor fix at best.
I tried to attach a photo but couldn't figure out how.
Thanks again
Dave
Old 01-16-2019, 03:15:28 PM
Thanks again
Dave
Wrap some electrical tape if you are waiting till the spring so it lessens that chance.
Generac iQ2000 Fuel Filter Replacement TJC111 Generac Generators (SEARS, etc.) 2 11-15-2016 10:07:17 AM
Generac Model 5860 QP75 Belt replacement runeatic Generac Generators (SEARS, etc.) 0 07-11-2015 09:33:51 AM
Generac Wheelhouse 5550 replacement fuel tank beachblue Generac Generators (SEARS, etc.) 2 07-11-2010 07:21:55 PM
Generac MC38 carburetor needs replacement tnau Generac Generators (SEARS, etc.) 0 03-28-2010 02:34:05 PM
Replacement coil for CCK BBerg Onan Generators 3 02-21-2008 09:43:27 PM
