Go Back   SmokStak > SmokStak® Shop Equipment Tools and Techniques > Air Compressors
Air Compressors Restoration, Repair and use of Shop and Industrial Air Compressors
Air Compressors
1929 service station equiptment co. air compressor
this thread has 3 replies and has been viewed 737 times
Old 12-12-2018, 11:15:21 AM
jawfly jawfly is offline
Default 1929 service station equiptment co. air compressor
This is my first post on this forum.
I have had a 1929 service station equipment co. air compressor for the last 30 or so years. It's always been slow but steady at coming up to pressure. With the lack of use lately it will only come up to about 10psi. It's a single cylinder w/intake and exhaust coming out of the top of the head. I pulled the valves out to clean them and the reed on the intake[more like a small flat disc approx 1/2" in diameter] was damaged. The exhaust valve seemed to work correctly. Is there any possibility of getting parts for this thing or does anyone have any info? I do understand how long of a shot this is, but thought I'd give it one any how.
Thanks,
Jawfly
The Following 2 Users Say Thank You to jawfly For This Post:
Old 12-12-2018, 01:24:15 PM
Default Re: 1929 service station equiptment co. air compressor
Lap the disc back to flat surface and re-use, if too damaged make a new one.
Old 12-12-2018, 02:14:51 PM
Doug Kimball's Avatar
jawfly,
How thick is the disk & what material?? Does a magnet attract it? Photo of disk & seat might help.
In Kennebunk, Maine;
Doug Kimball
Old 12-12-2018, 04:11:31 PM
Vanman Vanman is offline
And don't forget to hydro test the tank! Don't know how big it is, or what the operating pressure is, but odds are good that it's enough to be injurous or deadly were it to fail catastrophically.
Cooper Bessemer Compressor Station Doug Waggonner Oil Field Engines & Related Equipment 12 06-30-2011 03:47:01 PM
Unknown engines in compressor station -1910 jeeperforlife Unidentified Engines 4 08-15-2010 02:58:29 AM
Webster Service Station Sign Jon Rozevink Hit & Miss Gas Engine Discussion 9 09-11-2009 08:00:05 AM
PA Compressor Station photos from 1963 Robert Pence Hit & Miss Gas Engine Discussion 11 11-29-2006 10:10:02 PM
Other equiptment your engines can run. Tony Glaser Antique Engine Archives 7 02-15-2004 08:37:36 PM
