Go Back   SmokStak > SmokStak® Old Iron and Tractor Community > Farm + Industrial Antiques and Collectibles > Antique Washing Machines
Antique Washing Machines Old collectible washing machines as used on the farm.
Coil sollution for easy washer engine
this thread has 1 replies and has been viewed 1350 times
Old 01-23-2016, 12:03:58 PM
Tim Venetis Tim Venetis is offline
Default Coil sollution for easy washer engine
I got a maytag coil and the bolt patern was the same as a easy washer coil so I did a little modification to it. I took a small hammer and tapped the case all around and removed it. I cut the small wire which connected on to the sparkplug connection and I wrapped a spark plug wire around it and taped it. I then wrapped tape around the coil and plug wire to hold it put it on the engine and I get good spark.
The Following User Says Thank You to Tim Venetis For This Post:
Old 01-23-2016, 12:58:26 PM
Junkologist's Avatar
Images: 160
Default Re: Coil sollution for easy washer engine
Glad you found a fix!
Mike
SmokStak member #146
Leather coupling for Easy washer jdrj4 Antique Washing Machines 3 07-08-2014 04:31:09 PM
6HP International M first start easy on battery and coil bobgill2009 Antique Gas Engine Discussion 7 03-23-2012 03:01:38 AM
Easy way to test a coil? enginesilo Magnetos, Ignition Coils and Spark Plugs 8 04-03-2011 09:47:54 AM
Easy Washer Engine Junkologist Small Air Cooled Gasoline Engines 10 09-01-2009 09:01:04 PM
Easy Washer R Information needed! Robert Green Small Air Cooled Gasoline Engines 0 07-11-2009 08:57:28 PM
