Go Back   SmokStak > SmokStak® Old Iron and Tractor Community > Farm + Industrial Antiques and Collectibles > Antique Washing Machines
Antique Washing Machines Old collectible washing machines as used on the farm.
Maytag 92 exhaust pipe and belt size
this thread has 2 replies and has been viewed 1195 times
Old 05-14-2017, 09:55:57 PM
ttyR2 ttyR2 is offline
Default Maytag 92 exhaust pipe and belt size
Mounted up the Maytag 92 I have into my Maytag 80 washing machine. What length belt do I need? The old one has almost disintegrated, not sure the parts store will be able to measure it.
Also, what size is the flexible exhaust pipe supposed to be? I thought I read 1" but the ball muffler I have measures 1-1/8" ID at the inlet.
This machine has a faucet for the water drain. Someone had put friction tape around the end to try to keep water from leaking out around the knob, I would assume. Is there any way to seal the threads a bit? Or...did they just put too small of a rubber washer on it?
There is a long, broken, sprint bolted to one of the legs that appears to have probably been connected to the on/off mechanism on the left of this picture. Do you know if that spring is factory or should I remove it? Seems a bit odd to have a long gangly spring stretched clear across the machine.
Old 05-15-2017, 10:56:39 AM
gasenginerick gasenginerick is offline
Default Re: Maytag 92 exhaust pipe and belt size
The spring should be attatched from the leg to the rack that drives the agitator, the factory exhaust hose was 1 3/16 diameter and the drain should be a hose they measure 7/8 ID, modern 7/8 hose isn't as large on the OD but it works. I have pics but don't know how to get them on here.
Old 05-16-2017, 10:34:26 AM
Does the spring attach to the cotter key loop that is on the very end of the rack?
Here is another picture of the drain faucet I'm talking about. Did this drain setup come from the factor or did someone add it?
This is my other Maytag with the common style drain hose.
Onan MCCK 6500 belt pulleys and belt size? sdowney717 Onan Generators 3 06-02-2013 09:51:57 AM
Onan BFA Generator exhaust pipe size? tsdp Onan Generators 1 05-21-2012 09:59:35 PM
Need belt size for Maytag 33X washing machine. Marc P Maytag Engine Collectibles 0 09-15-2011 05:04:58 PM
Adapter to go from 1" pipe thread to regular exhaust pipe? LombardiniDiesel Small Air Cooled Gasoline Engines 2 02-07-2011 12:15:00 AM
FMZ 15hp exhaust pipe size? wydiver Antique Gas Engine Discussion 1 09-05-2010 08:31:52 PM
