Go Back   SmokStak > SmokStak® Old Iron and Tractor Community > Farm + Industrial Antiques and Collectibles > Maytag Engine Collectibles
Maytag Upright with no serial number
this thread has 7 replies and has been viewed 1077 times
Old 11-26-2016, 05:03:20 PM
firetuck firetuck is offline
Default Maytag Upright with no serial number
The title says it all. I have been looking for an upright for a long time and finally found one I could buy. I have it tore down and sandblasted all of the cast pieces. I know the serial number should be on the face of the flywheel but it is nowhere to be found. We're some of them like this? Could this be an early engine? Was there anyone reproducing flywheels at some point that I am unaware of?
Thanks in advance for any info.
ID:	268841   Click image for larger version
ID:	268842   Click image for larger version
Old 11-26-2016, 07:11:01 PM
DSRemodel DSRemodel is offline
Default Re: Maytag Upright with no serial number
i have more uprights with out numbers than with. don't know why
The Following User Says Thank You to DSRemodel For This Post:
Old 11-26-2016, 08:22:04 PM
Doug Oldenburg's Avatar
Doug Oldenburg Doug Oldenburg is offline
I have never been able to find a serial ## on mine.
"So Much Iron & So Little Money"
The Following User Says Thank You to Doug Oldenburg For This Post:
Old 11-27-2016, 09:45:09 AM
Arlie Levy Arlie Levy is offline
I don't know how true it is but I was told if there is no serial# it is an Elgin! For what it is worth. Maybe someone else will chime in and clear this up. Good luck. Arlie
The Following User Says Thank You to Arlie Levy For This Post:
That makes me feel better. I did find a book on uprights on Maytagshed.com. The book is out of circulation but you can open each chapter and get a small part to read. One of the chapters stated that many collectors felt the fly wheels with no numbers came from "field repairs and replacement". That's got me thinking if true, why did so many have to be replaced.
Old 11-27-2016, 09:46:59 AM
Also if anyone has that book, I would love to have a copy.
Old 11-27-2016, 09:47:58 PM
Usually the flywheels with no # indicate a replacement repair flywheel from the factory. I think very few left the factory with no serial number.
Kevin
The Following User Says Thank You to Kevin Weis For This Post:
Old 11-27-2016, 11:43:21 PM
bobeg bobeg is offline
If you look at the number of upright made " about 100,000 ". There not to many flywheels out without a number.
Upright Maytag Serial number Brian D. Maytag Engine Collectibles 6 08-09-2011 10:58:51 PM
Maytag upright serial #2715 D-carb MedicHamilton Maytag Engine Collectibles 0 02-04-2011 12:27:39 AM
New Maytag serial number Dale S Maytag Engine Collectibles 6 08-20-2010 05:46:35 PM
Maytag serial number Mike S Maytag Engine Collectibles 7 10-19-2009 10:19:29 AM
Maytag upright serial # list Bruce P Pederson Antique Engine Archives 2 12-29-2002 08:35:25 PM
