Go Back   SmokStak > SmokStak® Antique Engine Community > Small Air Cooled Gasoline Engines > Maytag Engine Collectibles
Maytag 92
this thread has 3 replies and has been viewed 855 times
Old 08-20-2016, 06:19:21 AM
livram40 livram40 is offline
Default Maytag 92
Information please, on the magneto back plate from a model 92 there is what I would call an oil catch ring, please excuse the description am new to Maytag ownership, this has the small tube that exits from rear of the mag. plate.
Can anyone tell me should there be felt or other material inside the ring as mine has nothing inside. Thank you
The Following User Says Thank You to livram40 For This Post:
Old 08-20-2016, 11:47:34 AM
turbo turbo is offline
Default Re: Maytag 92
Should be nothing inside. Its purpose is to collect the oil that drips out of the main bearing and direct it away from the magneto.
The Following 2 Users Say Thank You to turbo For This Post:
Old 08-22-2016, 01:11:52 PM
Exclamation Re: Maytag 92
Turbo s it. The ring and tube should be clean and free of gum and debris. make sure spiders did not make a nest in the tube! The maytag engines did not use seals on the cranks! they depended on the oil film left when the engine ran, to lube and seal the crank. Thus the need to run SAE 30 NON-detergent or TCW type 3 OIL in these slow speed engines. Modern lubes are too thin, and tend to blow thru the bearings. As turbo noted, the catch rind kept excess oil away from the points and coil. These engines like to slobber oil - nature of the beasts. If the bearings are worn, the oil blow by gets worse. If the crank moves when lifted more than a few thousandths, then the bushings are worn. If you don't load the engine, not too much of an issue, but if you intend to load it, if badly worn, you might consider new bushings and a rebuild.
Old 08-23-2016, 09:58:58 AM
Andrew M. many thanks for info. when I first got engine firing I did use the 2 stroke mix I run my other engines on [Villiers Marvil`s] but I noticed oil mix seeping through crank bushings, this was only for approx. 2 minutes running just to see how engine ran, I then used the recommended mix and no more seeping from bushes.
Engine is now broken down as am in process of a full refurb.
Maytag 82 and maytag upright Lvolling Maytag Engine Collectibles 1 03-27-2016 12:05:49 PM
Early Maytag Wooden Tub Maytag Washer Shelby Babcock Antique Washing Machines 16 12-30-2014 11:13:53 PM
Maytag Quick Action & Maytag Quart Can jamesrmorris1 Maytag Engine Collectibles 4 08-01-2013 09:40:59 PM
Odd barn find Maytag runs again...Maytag prototype or farmer fix? Mac Leod Antique Gas Engine Discussion 16 11-19-2008 12:45:49 AM
Will Maytag 72 power my Maytag washing machine. triplepass Maytag Engine Collectibles 9 11-14-2007 12:52:04 AM
