92 running problem fixed
this thread has 1 replies and has been viewed 791 times
Old 10-19-2016, 07:01:59 PM
Default 92 running problem fixed
I picked up a 'tag 92 recently and cleaned out the fuel tank and pick up. It started fine, but would quit after a few minutes of running. At first I thought it was old gas (about 30 days old), but when the tank was drained and fresh gas applied - same problem. It would run about 4 or 5 minutes and quit. I changed plugs, same deal. I finally decided to check compression. Found it! Cold, compression was excellent. Hot - virtually none! If I let sit 10 minutes, great compression again. Ok, so it needs new rings. Only one problem - when I pulled the cylinder, guess what I found - NO RINGS! Seems this engine was dis-assembled years ago, and was put back together with no rings! The grooves were in good shape, and they were full of carbon, so this engine was run a while this way. I thought of re-assembling it as-is just to make people try and decide what was wrong with it, but just ended up installing the new rings after cleaning off the carbon. The engine runs fine now! You never know what you will find!
The Following 3 Users Say Thank You to Andrew Mackey For This Post:
Old 10-19-2016, 07:17:35 PM
Smitty76 Smitty76 is offline
Default Re: 92 running problem fixed
That's crazy! Shows how good these engines are I guess.
Nelson Bros Fuel Problem Fixed Everett Hayden Small Air Cooled Gasoline Engines 0 10-27-2013 04:06:19 AM
Stover 1hp running problem Rubrmat Antique Gas Engine Discussion 1 03-11-2013 08:41:41 PM
disston kb6-ax running problem coyote62ny Chain Saw Collectors 4 11-21-2012 10:38:53 PM
Quirky LB running problem... George Andreasen Antique Gas Engine Discussion 5 11-21-2012 08:23:54 PM
hurcules running problem Sky Antique Gas Engine Discussion 17 09-16-2005 07:51:13 PM
