Go Back   SmokStak > SmokStak® Antique Engine Community > Small Air Cooled Gasoline Engines > Maytag Engine Collectibles
Maytag model 92 multi motor
this thread has 9 replies and has been viewed 1737 times
Old 11-28-2016, 07:47:54 PM
dalepratt dalepratt is offline
Default Maytag model 92 multi motor
I have a newly-rebuilt model 92, rebuilt by someone with a fairly good reputation but there is a problem, I think.
The engine won't start simply using the kick pedal, I have to spin it with a socket and drill on the flywheel nut to get it to fire...once warmed up, it starts easily and runs well. It is only on cold starts after the engine has set a while that this occurs. I always fill the tank to ensure the pick-up tube reaches the fuel.
After running, the base of the carb and the fuel tank top are covered in oil...not just a little, it runs down and drips from the bottom of the tank. I see oil traces from the screws, which are tight.
I don't know much about these, but hoping someone on here might have a clue. Thanks ahead for any advice you can give me.
The rebuilder isn't available for me to talk to.
Old 11-28-2016, 08:28:43 PM
Default Re: Maytag model 92 multi motor
Sounds like you need a new tank gasket and either a condenser or a new spark plug. The term "rebuilt" goes from getting it running and sell it, to a thorough go thru. I'm only an arm chair mechanic, from here.
The Following User Says Thank You to Pat Barrett For This Post:
Old 11-28-2016, 08:43:46 PM
Thanks Pat, have received the same info from other people, plus someone said to check the condition of the lead washers under the screws...well, there is only one, and it is split.
So I have those on order along with a new gasket. This engine was the "Best" out of a lot of four...the story went.
Thanks for your help, Pat. I appreciate it.
Old 11-28-2016, 11:24:31 PM
coyote62ny coyote62ny is offline
while you have the carb off to change the gasket take the check valve apart and clean all the parts with carb cleaner you could have a check valve that is not sealing the check valve is on the end of the fuel pickup pipe
The Following 2 Users Say Thank You to coyote62ny For This Post:
Old 11-29-2016, 09:59:18 AM
Arlie Levy Arlie Levy is offline
What kind of gas-oil mixture are you using? It should be 16-1. 8 oz of #30 non detergent oil to one gallon of gas. This mixture gives the proper lube. It keeps oil from escaping around the main bearings and maintains good compression. Any other oil run out all over just how you explain it. Keep us posted. Good luck! Arlie
The Following User Says Thank You to Arlie Levy For This Post:
Old 11-29-2016, 03:07:35 PM
Make sure the side of the carb that faces the engine is FLAT. Too many times people crank on the mount screws when the gasket leaks, and that bends the aluminum. Install the carb with a new gasket. If you cannot get replacement lead washers for the mount screws, you can use .020" thick vellum gasket material. You can get it from a good auto parts store or one of the sponsors here on the stak, like Lee Pederson. In a pinch, you could try a cerial box, but the cardboard may tear. Is the fuel pointer set properly? it should be pointed 90 degrees to the right when lightly seated. Full left when starting, and around vertical when running.
The Following 2 Users Say Thank You to Andrew Mackey For This Post:
Old 11-29-2016, 05:59:29 PM
Will do, and thanks. I'm thankful for any advice at all, for sure.
---------- Post added at 04:50:37 PM ---------- Previous post was at 04:44:55 PM ----------
I'm using the usual 16:1 with non-det. 30wt oil..started the engine today and paid attention to the carb. There is fuel seeping out around the lower screws and also around the base of the carb. Have new lead washers and gaskets on order, and hopefully this will stop the leak. Thinking of Gasoila soft set for a gasket sealer, unless anyone has a suggestion on what may work better. Thanks for the help guys, I really appreciate it.
---------- Post added at 04:59:29 PM ---------- Previous post was at 04:50:37 PM ----------
I'll check that carb for flatness, for sure. The brass screws are pretty beat up, and you can tell they have been torqued on pretty good. Ordered new gaskets, lead washers and new brass screws from a pretty well-reputed seller on ebay.
I'm soaking all of this in, fellas, and I sure will keep everyone updated, parts are due in at the first of next week,and I'll get started checking that carb this evening. I know checking it on a surface plate may be a little over-kill, but there's one here on the bench, and a mill standing in the corner if I need to shave off a few thou to make it flat...but I just hope it's bad gaskets. The needle does seem to be set correctly, according to your description. I hope I can stop at the carb.
Thanks again for the help. I figured this was the place to go to in order to find it.
The Following User Says Thank You to dalepratt For This Post:
Old 12-24-2016, 03:55:44 PM
Mark Shulaw Mark Shulaw is offline
In a pinch and you need a lead washer you can use a couple wraps of smaller diameter rosin core solder wrapped around the screw. It will mash out and form the washer. Make sure you clean out the under side of the screw that's dished in so that the new lead will fill it in.
Old 12-31-2016, 09:58:50 PM
You could also go to a sporting goods store and buy some lead split shot and flatten it out to make your washers.
Old 01-26-2017, 03:44:20 PM
Dalepratt, get your engine sorted out yet?
Maytag Model 92 Multi Motor dalepratt Live Auctions of Engines, Tractors and Old Iron 7 09-13-2016 07:10:57 PM
Maytag Multi-motor Book Bigjoedo Maytag Engine Collectibles 4 06-12-2011 02:43:26 AM
Maytag motor Model and others chrisco Maytag Engine Collectibles 5 05-05-2010 12:26:33 PM
Maytag Multi-motor for $800 on Kijiji?? Kammer0072000 Maytag Engine Collectibles 13 09-18-2008 04:14:14 PM
Fuller Johnson Multi.motor W.D McDonald Antique Engine Archives 0 01-01-2000 07:45:46 PM
