Go Back   SmokStak > SmokStak® Old Iron and Tractor Community > Horse Drawn Equipment
Horse Drawn Equipment Old iron designed for the purpose of hitching up to a horse or a team. This old iron machinery may be used or demonstrated while hooked to an old iron tractor too.
JD Sulky Plow
this thread has 15 replies and has been viewed 7424 times
Old 03-21-2010, 03:48:10 PM
SJerden SJerden is offline
Images: 50
Default JD Sulky Plow
I am looking for the large left wheel on a JD sulky plow. Anywhere near Southern Illinois? (1 or 200 miles?)
Old 03-21-2010, 04:17:04 PM
Images: 50
Default Re: JD Sulky Plow
I think its a John Deer plow, but have found no markings yet.
Old 03-22-2010, 12:09:27 AM
bradheiter bradheiter is offline
Can you find a number cast on the hub? It will help ID what you are looking for.
Brad H
Old 03-22-2010, 07:16:59 PM
murrayc murrayc is offline
fix it I fix this it's also a deere
Old 03-22-2010, 08:34:12 PM
Images: 50
That's a good idea. A couple of pieces of hammered flat steel could be cut and welded into the gaps, thanks murrayc
There's green and yellow paint on it. That's what makes me think its JD
Old 03-22-2010, 09:43:36 PM
Kent McMakin Kent McMakin is offline
I'm not a real expert on JD plows but, generally, John Deere is stamped on the tops of the beams and they have elliptical wheel spokes. For what it's worth.
Old 03-22-2010, 11:59:47 PM
Images: 50
Chats Tractors has one just like mine at
http://www.chatstractors.com/2003_JD_plow.htm
It does have sort of flat, or eliptical wheel spokes, but there is no wording on it other than numbers on the castings.
Old 03-23-2010, 12:05:42 AM
On the back side of a share you should find a mark.
Old 03-23-2010, 08:07:42 PM
Images: 50
On the back of the shears is MP212
Old 03-23-2010, 10:13:41 PM
Images: 50
Here's a better shot of it. I just picked this up at an estate sale last weekend (3-20-10)
New to me "Jacobsen Estate 30" + who can Id the sulky? mschreiber Garden Tractors / Mowers / Scooters 1 08-19-2009 09:55:34 PM
Avery sulky plow Pitalplace Horse Drawn Equipment 2 04-29-2009 08:25:27 AM
Jacobsen Park 30 with Sulky find James Wallace Garden Tractors / Mowers / Scooters 3 05-18-2008 10:16:03 PM
Monarch Tractor Sulky Tom G Antique Gas Engine Discussion 1 06-16-2006 11:48:56 PM
one big plow OldAgIron Farm + Industrial Antiques and Collectibles 6 02-28-2006 10:22:34 PM
