Onan Production Orders and Wiring Drawings Available
this thread has 107 replies and has been viewed 63118 times
Closed Thread
Old 03-10-2009, 02:17:22 PM
Billy J Shafer's Avatar
Default Re: Onan Production Orders and Wiring Drawings Available
Well Jarhead if you don't mind the help from a NAVY guy. I have the manual for a spec D DDA. 12 lead set. LO is T-4-5-6-10-11-12. L1 is T 1-7 through CT 21. L2 is T2-8 through CT 22. L3 isT3-9 through CT 23. Wire from Terminal 63 goes to H 3. The prints for wiring are on the covers for the generator section.
Old 03-10-2009, 05:01:31 PM
Jim Davis Jim Davis is offline
Thats Ok Bill I will pass on the kisses
  #43
Old 03-10-2009, 05:31:45 PM
Jarhead Jarhead is offline
Thumbs up Re: Onan Production Orders and Wiring Drawings Available
Billy anything you got will help I got the cover needing more than that though need wiring from control panel to Gen head got some wires cut that probably went to the meter base to the panel or switch panel I think they go to power leads for voltage and Hz meters and amps gage needing to know which goes where or where they can be connected safely three #8 gage solid copper wires came out of the panel in conduct and wires and conduct cutoff inside the machine maybe a few more wire with them possibly water heater unit wiring too. Thanks Guys P.S. not a problem Billy floated around on a few boats in my days 35-36 years ago LOL
  #44
Old 03-10-2009, 05:59:54 PM
I will get you a print. I was on the USS Saratoga CVA 60. True story the commander of the Marine Detachment on board. Last name was Pyle. When Gunny was not around we gave him hell over it. Was in 68-72 made the free nam trip.
  #45
Old 03-10-2009, 10:09:56 PM
U.S.M.C. 73-75 been around the world twice,been with 150 women and got 50 head of livestock to my credit, and 7 months in the fires and the scares true prove it, been a long time for me still got a few freinds left here and there in different branches of the service. If you get the prints let me know I'll PM you what you need Thanks Jarhead
  #46
Old 03-10-2009, 11:04:50 PM
EricWood's Avatar
EricWood EricWood is offline
Ike,
I don't know for sure what the original sub at the factory was at build time, but the one in your phono looks like the size of the original 115V/2200 or 2500 watt unit.
Check the ohms directly at the element. If a 2500 watt unit, should be about 5.29 ohms. If 2200 watts, 6.01 ohms; 2000 watt unit will be about 6.6 ohms. These values are all based on the older 115V rating instead of 120V.
As a comparison, a 240V/2200W heater, pulling 9.1 amps would have an approx. ohm value of 26.2 ohms.
Make sure you isolate at least one wire from the element before measuring, and hopefully the element is still good.
eric
  #47
Old 03-10-2009, 11:09:22 PM
Isaac-1 Isaac-1 is offline
thanks Eric
We have rain in the forecast for the next few days, but I will check it when things clear up.
Ike
  #48
Old 03-11-2009, 03:41:45 PM
Billy Jarhead here got the parts catalog today from one of the guys here onanparts member still needing a wiring diagrahm forthe unit hopfully Jim Davis will find me something close to my unit again Thanks for all the help, if you find anything paper or parts let me know never know what I may need next Thanks Jarhead
  #49
Old 03-11-2009, 06:45:58 PM
Andrew Albrecht's Avatar
Andrew Albrecht Andrew Albrecht is offline
Images: 69
Heres an odd one. its marine, water cooled.
Lister Diesel has informed me its June of 1946 production.
Model No W1O1L serial No. 66.290893
DC volts 12/15 Amps 74 Watts 1000
RPM 2100
Gen . No. 270231
Gen. Data 5101
Use 12 volt battery
here is my direct email aalbrecht001@cinci.rr.com
if you can give me any more info about it that would be great.
thanks andrew
I Get My Corn From A Jar
  #50
Old 03-12-2009, 07:23:50 PM
Jarhead check your email. I sent you the stuff for spec 13958D. If it is not close let me know. I am sorry it took so long but work is hell these days.
Jim
The Following User Says Thank You to Jim Davis For This Post:
Closed Thread
Onan 12JC-5DRV/166P drawings needed BergmanJ Onan Generators 19 07-04-2009 06:52:12 PM
Onan DJC wiring id Jdnutinwa Onan Generators 3 10-07-2008 11:32:43 PM
Onan CCK wiring sam c Onan Generators 2 06-23-2008 01:33:06 PM
