Wico EK Trip Mechanism Help
this thread has 21 replies and has been viewed 2136 times
Old 07-25-2017, 05:56:11 PM
mbaldwin mbaldwin is offline
Exclamation Wico EK Trip Mechanism Help
Hi so i recently got a Wico EK magneto for my stover ct2 engine. i pulled it off of a fully working and running 2 hp fuller johnson. examining the trip mechanisms on both my engine and the fuller, the mounting bracket, trip finger, and rocker arm are all 100% identical. So i mounted that wico magneto on my engine and installed all of the necessary components for the trip mechanism. Problem is, i seem to be having a weaker trip and i can get NO spark at all. Everything is the same between the fuller's trip mech and the stover's. but i just cant get that strong click no matter how much i tinker with it. im at all loss and ive tried adjusting EVERYTHING. Help please!!! Thanks
Old 07-26-2017, 02:35:55 AM
cobbadog cobbadog is offline
Default Re: Wico EK trip mechanism help
Make sure that the magneto is making a good clean earth to the engine and not through paint or grease.
Does the magneto work properly again if you re-fit it to the original engine?
Old 07-26-2017, 03:12:59 AM
gasenginerick gasenginerick is offline
Try replacing the spring in the trip finger I found when they get weak the armature won't pull away even off the poles
Old 07-26-2017, 12:20:36 PM
The magneto works perfectly when i put it back on the fuller johnson
---------- Post added at 11:20:36 AM ---------- Previous post was at 11:04:48 AM ----------
I went and checked over everything. The magneto is solidly grounded to the engine, the spring in the trip finger is pretty strong (it takes some good effort to compress it) and my spark plug IS good. Thanks for everyone's help
Old 07-27-2017, 05:41:34 PM
Upon further inspection, i have electricity every time the magneto trips. But its very weak, and i am able to hold the wire while it trips and feel very little shock. I know that for the wico ek mags, it should be a pretty powerful spark. The magneto works wonderfully with the fuller, so i dont think that its the magnets or something.
Old 07-27-2017, 05:54:18 PM
Only a suggestion, but some times you can loosen the 2 - 5/16" mounting bolts and slightly tilt the mag forward or backward and it will make a lot of difference in how it acts. Cost nothing to try.
Old 07-29-2017, 09:12:52 PM
Kevin Weis Kevin Weis is offline
Try re-charging the magnets. Maybe they got weakened with the move some how.
Kevin
Old 07-29-2017, 09:36:28 PM
Steve Kreiner's Avatar
Steve Kreiner Steve Kreiner is offline
Images: 14
The magnets will also lose there magnetisem and will not take a charge then you will have to buy the new magnets.
Old 07-30-2017, 08:25:23 AM
SparkyMil SparkyMil is offline
Just removing the mag should not cause the lost of magnetism. If the mag functions on the fuller & Johnson and not on the stover , I would be taking a close look at the tripping mechanism on the stover and suspect the trouble to be in that.
Jim
Old 07-30-2017, 01:49:44 PM
Are you swapping trip parts from engine to engine, or are you swapping only the mag? I ask because in another post you state:
"...the spring in the trip finger is pretty strong (it takes some good effort to compress it)..."
Even rusted up drive springs take "a goodly amount" to compress them, but they don't work worth a hoot. The springs are what make it all function; if they aren't right up to snuff, you can adjust 'til the cows come home and still not have a reliable spark.
There are three springs involved. The little spring that lifts the trip finger has the least affect on the speed of the snap but still plays a part. I have seen this spring replaced with one that was so heavy that it wouldn't allow the armature to drop. The armature return spring definitely affects the speed of the snap. If the spring is incorrect or is compressed too far, it will slow the speed of the snap. This spring is adjusted by loosening the big nut on the rocker shaft and rotating the spring retainer. The third spring is, of course, the drive spring. This spring has a very daunting task before it and requires its full strength to carry out that task effectually.
In addition to having appropriate springs in place, the rocker and rocker shaft must be absolutely free from rust, paint, dried oil, etc. and be well lubricated. The rocker also must not bind in the yoke at the bottom of the armature. The depth setting for the trip finger needs to be sufficient to pull the armature its required distance. The trip finger must be free to slide all the way onto its seat at the retard lever, and it must have enough free downward movement to allow the armature to drop once it has been tripped. The trip finger itself has a screw in the back of it where it slides into the bracket. The end of this screw is what contacts the retard lever (if it's down). This screw is not an adjustment and must be bottomed in the trip finger. If it has been replaced with something else, all bets are off. The chances of its having been replaced or even tampered with are small, but I've seen it.
These are but a few things to contemplate. The WICO EK system is simple and reliable, but it's a balancing act, so everything must be correct.
Kirk
Need help on Massey mag trip mechanism Massey Guy Antique Gas Engine Discussion 2 01-19-2015 05:11:48 PM
Stover KE Trip Mechanism, etc. - Is this right? MotoXkid Antique Gas Engine Discussion 5 05-07-2012 07:39:14 PM
Waterloo Boy odd trip mechanism help Rick I Antique Gas Engine Discussion 2 06-29-2011 07:30:17 AM
Wico EK trip Steve Gerot Antique Engine Archives 2 06-20-2002 09:53:03 PM
Witte Mag Trip Mechanism/Springs Anthony Pitts Antique Engine Archives 3 05-18-2001 11:01:08 AM
