Mag went bad on my Briggs
this thread has 8 replies and has been viewed 764 times
Old 09-06-2017, 07:10:16 AM
AugerCreek AugerCreek is offline
Default Mag went bad on my Briggs
The mag went on my 14hp Briggs so I'm wondering if I can use just the points to operate a automotive coil to develop the spark for ignition? What else needs to be done? Resistor added or not?
Old 09-06-2017, 09:19:04 AM
Default Re: Mag went bad on my Briggs
Firdt, you need to find out if the points are normally open or closed. If closed, a battery and coil will not work -l burn out.
If you use an automotive coil, you probably should use a resister, to save wear on the points. t
Old 09-06-2017, 11:32:23 AM
The points are normally open. Thanks for your answer!
Old 09-11-2017, 02:26:11 PM
Good info, did just as you suggested and it runs better than it has for a long time. Now to put a alternator on it. Does it make any difference on rotation?
Old 09-12-2017, 02:46:53 PM
The alternators cooling fan matters and the brush holders may be offset slightly,so in closing I would say yes.
Old 09-12-2017, 03:32:30 PM
Motormowers's Avatar
I would go with a small Nippondenso internally regulated one like whats used on small diesel compact tractors like Kubota or Cub Cadet. They work great and last a long time. I put one on my 180D Benz to replace the generator and couldnt be happier.
Remove the all rotten apples out of your basket of life and toss them in the trash where they belong.
Old 09-13-2017, 07:05:58 AM
Thanks much guys
Old 09-13-2017, 07:45:41 AM
Rotation direction on an alternator makes no difference. But the fan does work better when spun in the normal direction. Just run it and look for heat buildup. You should be fine.
Old 09-14-2017, 06:15:12 AM
I see on e-bay a alternator for a John Deere lawn tractor that appears to not have a fan also has two or three wire connection, how would I determine which wires go where?
Briggs ~ MAY DAY MAY DAY - Briggs Z coil rewind badly needed! Jack H Small Air Cooled Gasoline Engines 6 03-21-2017 10:50:23 AM
Briggs: Advice on Briggs ZZ & I pistons GreyWulf Antique Gas Engine Discussion 3 12-25-2014 10:31:05 PM
Briggs I Signal Corps Genset/ Briggs 6 Nevr-Enuf-Stuf Small Air Cooled Gasoline Engines 9 01-17-2013 12:38:02 AM
Briggs parts interchange not in Briggs book Ken Karrow Small Air Cooled Gasoline Engines 4 09-17-2011 12:50:16 AM
Original Briggs pump?+1943 briggs NPR6 41Briggs Small Air Cooled Gasoline Engines 4 12-30-2009 11:21:28 AM
