Go Back   SmokStak > SmokStak® Old Iron and Tractor Community > Vintage Construction Equipment
Vintage Construction Equipment Graders, Shovels, Fork lifts, Dozers & Crawlers, Pay loaders & Fork lifts
want 24" split ring wheel used on old grader.
this thread has 4 replies and has been viewed 921 times
Old 07-06-2017, 06:43:08 PM
mag473 mag473 is offline
Default want 24" split ring wheel used on old grader.
Want to buy. 24" x 9" split ring ( not split rim) wheel as used on some old graders. Would consider a wheel needing repair.
Old 07-06-2017, 06:49:55 PM
Doug Oldenburg's Avatar
Doug Oldenburg Doug Oldenburg is offline
Default Re: want 24" split ring wheel used on old grader.
I would be willing to sell you this rim for about $3000, but you would have to take the Cat. 10 grader with it. Runs & operates. Diesel.
"So Much Iron & So Little Money"
The Following User Says Thank You to Doug Oldenburg For This Post:
Old 07-06-2017, 07:37:21 PM
Gene Williams Gene Williams is offline
We just finished changing tires on a #11 Motor patrol with 13.00 - 24 wheels and noticed they are nearly if not the same wheel as used on Oliver 35 tractors. Might be something to check into. Also check over on ACMOC.org as there as people over there that are very knowledgeable about this stuff.
The Following User Says Thank You to Gene Williams For This Post:
Old 07-06-2017, 11:18:25 PM
Thanks for the leads.
Old 07-07-2017, 09:27:42 AM
jkt73 jkt73 is offline
Call Equipment Salvage in Cambridge Oh 740-439-5512 they should have what you need.
A "split" transfer switch Dave Edmonds Onan Generators 10 02-03-2016 01:00:04 AM
Wanted 24 X 9 split ring rims mag473 Antique Farm Tractors 4 10-13-2015 09:42:51 PM
Wanted 24 X 9 split ring rims used on Cat 10 mag473 Vintage Construction Equipment 0 10-09-2015 08:53:28 PM
WANTED: IHC Axial Wheel Ring Steve Alt Antique Gas Engine Discussion 0 07-29-2013 10:33:03 PM
Small leaning wheel grader wanted bluebluejays Horse Drawn Equipment 0 05-17-2010 08:43:16 PM
