Go Back   SmokStak > SmokStak® Old Iron and Tractor Community > Vintage Construction Equipment
Vintage Construction Equipment Graders, Shovels, Fork lifts, Dozers & Crawlers, Pay loaders & Fork lifts
Aircraft tug Id
this thread has 31 replies and has been viewed 3450 times
Old 10-20-2016, 09:09:36 AM
E27N's Avatar
E27N E27N is offline
Default Aircraft tug Id
Since this doesn't really fit anywhere else I thought I'd post it here,
I was given this tug by my bosses FIL, I thought it was a Clark but a google image search doesn't seem to come up with anything that resembles it. It's got a 225cu in Chrysler slant 6 and a torqueflite auto trans that goes to a reduction box that drops the drive to the rear of the diff.
Any ideas ?
Cheers Andrew
Never let the truth get in the way of a good story....
Old 10-20-2016, 01:56:47 PM
N84434 N84434 is offline
Default Re: Aircraft tug Id
Some older Tugs used slant 6's, and I believe Wollard made them as well. It sure looks like a Clark, but those primarily had Ford 6 cyl. engines in them..
No DATA plate anywhere, huh?
The Following User Says Thank You to N84434 For This Post:
Old 10-20-2016, 05:12:01 PM
DCamp DCamp is offline
Might it be a Towmotor?
The Following User Says Thank You to DCamp For This Post:
Old 10-20-2016, 05:30:12 PM
Dave Myers Dave Myers is offline
My first thought is a United, from Chesterton IN.
David
The Following User Says Thank You to Dave Myers For This Post:
Old 10-20-2016, 06:13:22 PM
E27N's Avatar
Looked everywhere ! There is the remains of 4 rivets under the dash panel and my thinking is it was there but was removed at some point. It was still in use at Perth airport 10 yrs ago at one of the workshops there, but was decommissioned for the hydraulic handbrake. Bosses FIL saved it from scrap to use at his yacht club for shifting boats around etc, but the club didn't want to spend money for new rear tyres so it ended up at a small acreage he owned. (Where the pics were taken ). I should also mention it's construction yellow under the white paint.
Old 10-20-2016, 08:28:13 PM
Thaumaturge Thaumaturge is online now
Terry over on machine builders network has an identical model. Calls it "big ugly". I'll inquire with him who made them and get back to you. Might be interesting to read his posts about his. http://kramerville.net/ubb/
Doc
Got Dčja Vu and amnesia at the same time and forgot that I had been here before....
Old 10-21-2016, 12:08:27 AM
jgreen416 jgreen416 is offline
I don't think any of the tugs where I work are vintage, but we have quite an assortment. Mostly Clarks but FMC, Stewart & Stephenson and some others I would have to research, all in daily use.
JG
The Following User Says Thank You to jgreen416 For This Post:
Old 10-21-2016, 12:11:08 AM
Posted pics?
ID:	265961   Click image for larger version
ID:	265962   Click image for larger version
ID:	265963   Click image for larger version
Old 10-21-2016, 12:13:12 AM
Couple more.
JG
ID:	265965   Click image for larger version
Old 10-21-2016, 01:11:11 AM
akuna akuna is offline
I have one only different.
It was made in Hillsboro Oregon out of odd parts. Electric, ride on it standing on a pad and you tilt forward to go forward, and yes back to stop. Hand speed control. Was obviously used for small aircraft. unfortunately it was too close to his burn pile and the tires burned off of it. Speed control is messed up, however the motor works.
If I never put it back together for moving trailers or something, I will use the axle to make a kid sized dragster or something.
The Following User Says Thank You to akuna For This Post:
Aircraft Turbosupercharger Heins Blacksmithing and Metallurgy 32 06-14-2014 10:48:54 AM
GE Aircraft Generator Horse Power at 511 Generators & Electric Motors General Discussion 3 11-07-2010 04:02:34 PM
Aircraft Generator catdoo Military MEP and Aircraft Gen-Sets 14 06-01-2010 11:09:21 PM
aircraft engine Robert Johnson Antique Engine Archives 7 02-22-2001 02:36:39 AM
