Farmall Regular; help wanted
this thread has 47 replies and has been viewed 7665 times
Old 01-26-2016, 04:46:18 AM
IHCparts IHCparts is offline
Default Re: Farmall Regular; help wanted
Hi Wimpie,
That is indeed the same type of exhaust we have on our Regular . As we want to rebuild the center part (tube), would it be possible to make some detailed pictures? Maybe even from the inside of the tube? I think there should also be a mounting bracket on the back side, do you have this as well?
Regards, Frank
Old 02-06-2016, 02:53:15 PM
Wimpie Fourie Wimpie Fourie is offline
Thumbs up Re: Farmall Regular; help wanted
Hi Frank, Sorry for the late reply but I might have bad news bacause I found that the centre tube had been brazed at the joint and be sure some person had it been redone at some stage, any how I am going to give you the sizes as I found them.
Inner tube OD 66mm, length 210mm with 14 rows of holes in the length and 9 holes per row staggered to the followig row measuring 10mm and 20mm apart.
Outer tube 152mm in length.
I wonder what the designer engineer coments would be on these sizes!!!
The only part missing on the tractor is the driptray at the bottom of the carburator, any info about it?
The tractor runs pretty well with this exhaust.
Thanks and Regards, Wimpie.
The Following User Says Thank You to Wimpie Fourie For This Post:
  #43
Old 02-08-2016, 04:35:34 AM
Hi Wimpie,
Thanks for your reply, any dimensional info is welcome as till now I did not have any.
I will start building the exhaust on short notice and keep you informed on the progress.
Do you (or anyone else) know if there should be silencing material inside?
Old 02-08-2016, 04:50:10 AM
Hi Wimpie,
To come back to your question regarding the drip tray, I am pretty sure these parts should be available via used parts dealers like Biewer tractor parts (USA).
Maybe someone who reads this post might have one laying around..
Name:	farmall reg 3.jpg
The Following User Says Thank You to IHCparts For This Post:
  #45
Old 02-08-2016, 12:58:43 PM
Hi Frank,
About silencing I realy do not know, because when stripping it to pieces there where no sighns of any and thanks for the close up view of the drip tray I will be able to copy it.
  #46
Old 02-08-2016, 01:18:08 PM
GADavis GADavis is offline
In don't think any one has addressed the question of the drawbar with side brackets on it. They are most likely for attaching a sickle bar mowing machine like used for pasture mowing years ago.
The Following User Says Thank You to GADavis For This Post:
  #47
Old 02-10-2016, 05:13:08 AM
Thanks for you reply, I agree it is most likely to be something like a sickle bar mower. I would like to "proof" it with pictures. And in the end it would be ultimately great to find the implement which fits these brackets.
It is for sure one of the first fast hitch/snap coupler like solutions!
Old 03-04-2018, 09:49:44 AM
It has been quite some time since this topic was active. At the time the mystery of the hitch remained unsolved, but about half a year back we found the answer. Thought I might share it.
On the Nordhorn 2017 show we found a (French build) Vendeuvre tractor with mounted Viaud plow. It looks like the hitch is part of the plow mounting. See attached pictures. Again a confirmation that our regular spend it working life in France.
Last but no least I have added a section view picture of the Regular export muffler from the original German part catalog.
ID:	304631   Click image for larger version
ID:	304632   Click image for larger version
ID:	304633   Click image for larger version
The Following 2 Users Say Thank You to IHCparts For This Post:
Farmall Regular Help 30-90 Russell Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 28 08-19-2017 11:16:02 PM
And the two shall become as one. Farmall Regular NW Sloroll Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 38 09-18-2013 04:25:07 PM
Another farmall regular Russ Hamm Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 1 05-28-2013 05:29:03 PM
Farmall regular falconry63 Antique Farm Tractors 6 02-28-2012 02:51:33 PM
Farmall Regular WildIrishman52 Antique Farm Tractors 2 06-09-2009 02:24:55 PM
