Rumely Oil Pull L 15-25 Parts and Advice Wanted
this thread has 174 replies and has been viewed 19058 times
Old 02-16-2018, 09:23:44 PM
CBarth66 CBarth66 is offline
Default Re: Rumely Oil Pull L 15-25 Parts and Advice Wanted
No, i'm not concerned about the chipped sleeve. That clutch piece is really thin on the wear surfaces and would take a lot of brazing and finishing. My machine shop said they could probably do it, but I told them i'd try to find one better first. I'll have to weigh the cost differences as I get into it more. I will get new valve guides if knurling the old ones is not a good option. Anyone replacing sleeves back in the block on a Rumely, remember to line up the marks so the oiler tubes from the block to the sleeve line up.
The Following 3 Users Say Thank You to CBarth66 For This Post:
Old 02-20-2018, 06:47:49 AM
The clutch drive disc was loose on the crankshaft, so we bored out the disc and installed a sleeve to tighten it up. The crank was polished and shows very little wear. The brass bushings in the belt pulley are in real good shape so they will be reused. They were taken out so the pulley could be preheated and brazed to repair the small crack. I thought these bushings would be wore and caused the two drive gears to wear out so badly, or maybe it was just a lack of lubrication. We are working with the pistons now and got a price from Niagara rings and they are quite pricey. Does anyone have any other source for piston rings?
ID:	303577   Click image for larger version
ID:	303578   Click image for larger version
ID:	303579   Click image for larger version
Old 02-21-2018, 12:16:21 AM
Try OTTO Gas Engine Works.......site sponsor.......
http://www.ringspacers.com/
  #174
Old 03-01-2018, 10:36:39 PM
I did get a much better clutch collar from Biewers. As you can see in the pics this one has a much better wear surface inside. I probably would have had more cost in repairing the one I had than what I purchased this one for. You can also see the one that I took off the tractor and how wore it was. The two have different part numbers (c5p2733 and c5p2732), but look the same. The one that came from Biewers had some steel blue paint on it so it must have been on a later superpower, or maybe from a different model like a W? Anyway it should work fine. I am going to have the rim on the sleeve (the round piece with arms) built back up to fit the inside of the collar, and put new pins on all the linkages. This should make a nice working clutch. Still working with a couple of people for rings.
ID:	304399   Click image for larger version
ID:	304400   Click image for larger version
ID:	304401   Click image for larger version
  #175
Old 04-18-2018, 09:28:58 PM
I am getting the rings from Otto engine, but may be a while before Dave has them made. In the meantime the top two ring grooves are being machined out to fit 5/16 rings, and I'm working with the crankshaft and main bearings trying to get the shims right. Should there be any clearance at all with the crankshaft end play? I know it should have no resistance and turn freely. I'm having the belt pulley repaired by the same man who repaired the transmission housing. The crack turned out to be longer than I thought. At first I was just going to have the noticeable crack on one side repaired and not mess with the machined side for the clutch, but after preheating and brazing the crack showed up on the clutch side too. So now it is going to be cut out, brazed and machined down. I'm so glad I tore this tractor completely down to find things like this. Here are pics of the belt pulley. More to come soon.
ID:	308584   Click image for larger version
Rumely Oil Pull model M 20-35 Parts and Advice Wanted neilthewheel Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 14 03-27-2018 09:40:35 AM
Case 15-27 crossmotor parts and advice wanted! neilthewheel Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 8 01-01-2016 02:15:25 PM
Onan 15JC - need to pull genset any advice? Larry96 Onan Generators 4 07-21-2011 07:43:44 AM
14 -28 Rumely parts wanted fryguy Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 2 08-24-2009 12:09:09 AM
rumely oil pull tim w Antique Gas Engine Discussion 1 05-16-2007 10:00:25 PM
